width25%
width50%
width25%
Location
The Filter Generator utility is included with the V-Ray installation. See its location according to your host application:
typecircle
Excerpt
File Options
Image Modified
The file menu shows options for saving and loading presets and exporting the final filter kernel.
Radial Symmetric Pattern Parameters
width20%
width60%
Image Modified
width20%
The Radial Symmetric Pattern parameters control the scale of the overall Lens Filter.
Shape – Adjusts the size of the pattern.
Corona Flare Lines Pattern Parameters
width20%
width60%
Image Modified
width20%
The Corona Flare Pattern parameters control the amount of rays emanating from the light source.
Diametric – When enabled, mirrors the pattern across the center.
Radius – Controls the size of the pattern radius.
Number Of Lines – Controls the number of lines in the pattern.
UI Expand
titleClick here to expand the Corona Flare Lines Pattern Example
This example demonstrates how different values of the Number of Lines parameter affect the lens effect. Increasing the Number of Lines value produces more rays emanating from the light source while decreasing it lowers the number of rays.
The last image also has the Diametric parameter enabled, which mirrors the rays pattern across the center (thus producing symmetrical flares).
width25%
width50%
Image slider
Panel
borderStylenone
Image Modified
Number Of Lines = 100, Diametric is off
Panel
borderStylenone
Image Modified
Number Of Lines = 20, Diametric is off
Panel
borderStylenone
Image Modified
Number Of Lines = 5, Diametric is off
Panel
borderStylenone
Image Modified
Number Of Lines = 5, Diametric is on
width25%
Special Flare Lines Pattern Parameters
width20%
width60%
Image Modified
width20%
The Special Flare Pattern parameters control the pattern of the Special Flares Lines.
Ray Pattern Dropdown – Determines the number of Ray groups.
Radius – Scale of the Special Flares Lines Lens kernel in Percent.
Number of Lines – Determines the amount of lines used in each ray pattern.
Range – Controls the spread of the Ray Pattern.
Rotation – Rotates the entire Special Flare Lines Pattern in degrees.
UI Expand
titleClick here to expand the Special Flare Lines Pattern Example
This example shows the effect of Range and Ray Pattern parameters on the lens appearance. The Number of Lines is set to 10 for all images.
width25%
width50%
Image slider
Panel
borderStylenone
Image Modified
Number of Lines = 10, Range = 10, Ray Pattern = 2
Panel
borderStylenone
Image Modified
Number of Lines = 10, Range = 10, Ray Pattern = 4
Panel
borderStylenone
Image Modified
Number of Lines = 10, Range = 10, Ray Pattern = 6
Panel
borderStylenone
Image Modified
Number of Lines = 10, Range = 10, Ray Pattern = 8
Panel
borderStylenone
Image Modified
Number of Lines = 10, Range = 40, Ray Pattern = 2
Panel
borderStylenone
Image Modified
Number of Lines = 10, Range = 40, Ray Pattern = 4
Panel
borderStylenone
Image Modified
Number of Lines = 10, Range = 40, Ray Pattern = 6
Panel
borderStylenone
Image Modified
Number of Lines = 10, Range = 40, Ray Pattern = 8
Panel
borderStylenone
Image Modified
Number of Lines = 10, Range = 80, Ray Pattern = 2
Panel
borderStylenone
Image Modified
Number of Lines = 10, Range = 80, Ray Pattern = 4
Panel
borderStylenone
Image Modified
Number of Lines = 10, Range = 80, Ray Pattern = 6
Panel
borderStylenone
Image Modified
Number of Lines = 10, Range = 80, Ray Pattern = 8
width25%
Lenticular Halo Parameters
width20%
width60%
Image Modified
width20%
The Lenticular Halo parameters control the bounds of the halo.
Inner Radius – Sets the inner bounds of the Lenticular Halo
Outer Radius – Sets the outer bounds of the Lenticular Halo.
UI Expand
titleClick here to expand the Lenticular Halo Example
This example shows how changing the inner and outer bounds values affects the Lenticular Halo.
width25%
width50%
Image slider
Panel
borderStylenone
Image Modified
Inner Radius = 20, Outer Radius = 40
Panel
borderStylenone
Image Modified
Inner Radius = 20, Outer Radius = 60
Panel
borderStylenone
Image Modified
Inner Radius = 20, Outer Radius = 80
Panel
borderStylenone
Image Modified
Inner Radius = 20, Outer Radius = 120
Panel
borderStylenone
Image Modified
Inner Radius = 40, Outer Radius = 120
Panel
borderStylenone
Image Modified
Inner Radius = 80, Outer Radius = 120
width25%
Mix Parameters
width20%
width60%
Image Modified
width20%
The Mix parameters control how the Lens Parameters mix together into the final Filter kernel.
Pattern 1 – Sets the percentage Radial Symmetric Pattern 1 is mixed with the final Filter kernel.
Pattern 2 – Sets the percentage Radial Symmetric Pattern 2 is mixed with the final Filter kernel.
Halo – Sets the percentage the Lenticular Halo has on the final Filter kernel.
Aspect – Determines the Aspect Ratio of the final Filter kernel.
Apply Corona Flare Pattern – Enables kernel filtering with the Corona Flare Pattern.
Apply Special Flare Pattern – Enables kernel filtering with the Special Flare Pattern.
UI Expand
The following examples show how lens parameters can be mixed together to achieve a final filter kernel.
width25%
width50%
Image slider
Panel
borderStylenone
Image Modified
Apply Corona Flare Pattern is on, Halo = 0, Diametric is on, Number of Lines = 5
Panel
borderStylenone
Image Modified
Apply Special Flare Pattern is on, Halo = 0, Number of Lines = 10, Range = 40, Ray Pattern = 6
Panel
borderStylenone
Image Modified
Apply Corona Flare Pattern is on, Apply Special Flare Pattern is on, Halo = 0, Number of Lines = 10, Range = 40, Ray Pattern = 6
Panel
borderStylenone
Image Modified
Apply Corona Flare Pattern is on, Apply Special Flare Pattern is on, Halo = 35, Number of Lines = 10, Range = 40, Ray Pattern = 6
Panel
borderStylenone
Image Modified
Apply Corona Flare Pattern is on, Apply Special Flare Pattern is on, Halo = 70 Number of Lines = 10, Range = 40, Ray Pattern = 6
width25%
Anchor
References
References
