This page contains information about V-Ray's standalone Lens Effects Filter Generator.
Floatingpagetoc |
The Filter Generator is a tool to create HDR filter kernals kernels for use in the V-Ray Frame Buffer Lens Effects' Glare Image parameter.
Excerpt |
File Options
The file menu shows options for saving and loading presets and exporting the final filter kernel.
Radial Symmetric Pattern Parameters
The Radial Symmetric Pattern parameters control the scale of the overall Lens Filter. Shape – Adjusts the size of the pattern.
Corona Flare Lines Pattern Parameters
The Corona Flare Pattern parameters control the amount of rays emanating from the source of light. Diametric – When enabled, mirrors the pattern across the center. Radius – Controls the size of the pattern radius. Number of Lines – Controls the number of lines in the pattern.
Special Flare Lines Pattern Parameters
The Special Flare Pattern parameters control the pattern of the Special Flares Lines. Ray Pattern Dropdown – Determines the number of Ray groups. Radius – Scale of the Special Flares Lines Lens Kernal kernel in Percent. Number of Lines – Determines the amount of lines used in each ray pattern. Range – Controls the spread of the Ray Pattern. Rotation – Rotates the entire Special Flare Lines Pattern in degrees.
Lenticular Halo Parameters
The Lenticular Halo parameters control the bounds of the halo. Inner Radius – Sets the inner bounds of the Lenticular Halo Outer Radius – Sets the Outer bounds of the Lenticular Halo.
Mix Parameters
The Mix parameters control how the Lens Parameters mix together into the final Filter Kernalkernel. Pattern 1 – Sets the percentage Radial Symmetric Pattern 1 is mixed with the final Filter Kernalkernel. Pattern 2 – Sets the percentage Radial Symmetric Pattern 2 is mixed with the final Filter Kernalkernel Halo – Sets the percentage the Lenticular Halo has on the final Filter Kernalkernel. Aspect – Determines the Aspect Ratio of the final Filter Kernalkernel. Apply Corona Flare Pattern – Enables filtering of the Kernal kernel with the Corona Flare Pattern. Apply Special Flare Pattern – Enables filtering of the Kernal kernel with the Special Flare Pattern. |
