This modifier allows you to paint the initial and bend directions for VRayFur objects so that you can sort of "style" the appearance of VRayFur.
Download for 3ds Max 20132016-20202023: VRayFurStyler_VRayNext.zip .52023.zip
For 3ds Max versions that use the Plugin Package Format (2022 and later) the .dlo file needs to be added to C:\ProgramData\Autodesk\ApplicationPlugins\VRay3ds Max20nn\plugins, and the XML must be manually edited so that it includes the new DLO in the list here: C:\ProgramData\Autodesk\ApplicationPlugins\VRay3dsMax20nn\PackageContents.xml (where nn stands for the number of V-Ray for 3ds Max version).
Example:
Code Block |
<ComponentEntry AppName="VRayFurStyler" Version="5.20.23" ModuleName="./plugins/vrayfurstyler2022.dlo" /> |
Mudbox to .vrmesh exporter
