Auto Exposure – Automatically – Automatically determines an appropriate exposure value for the render. This option requires Light Cache in Single frame mode. Note that the Auto Exposure does not take into account pixels with zero Alpha value.
Auto White Balance – Automatically – Automatically determines a suitable white balance value for the image. This option requires Light Cache in Single frame mode. Note that the Auto White Balance does not take into account pixels with zero Alpha value.
Disabled – No white balance is used, only color correction. RGB Temperature
Auto Corrections Mode – Specifies which camera and/or views to use the automatic exposure and white balance setting. This option is available only if Auto Exposure/Auto White Balance are enabled.
All Cameras – Applies Auto Exposure and Auto White Balance to – Applies Auto Exposure and Auto White Balance to all cameras, regardless of their local exposure settings. Cameras Without Exposure – Applies Auto Exposure and Auto White Balance only – Applies Auto Exposure and Auto White Balance only to cameras with no local exposure settings.
