This page discusses render channels in general, with links to pages for more details.
Render Channels are a way to break out renders into their component parts such as diffuse color, reflections, shadows, mattes, etc. This gives fine control over the final image when using compositing or image editing applications to re-assemble the component elements. Render channels are also sometimes known as render passes or render elements.
Render channels appear in the V-Ray Frame Buffer (VFB) and can be viewed from the drop-down at the upper left corner of the VFB. They can also be saved out of the VFB as many common file formats.
The list of render channels that are supported by V-Ray can be found on the List of Supported Render Channels page. All render channels support native V-Ray materials.
||out Network|| > V-Ray Render Elements node > V-Ray > Render Channel
Section | ||||||||||
Add Render Elements
In order to add render elements to the render:
Fancy Bullets | ||
Fancy Bullets | ||
