The Z-Depth Render Channel is a grayscale image that renders each pixel based on its distance from the camera in the view.
Section | ||||||||||||||||
Section | |||||||||||||||||
Invert zdepth
The Depth Black and Depth White values in the Z-Depth Render Element can be inverted by enabling the Depth Invert option.
The Z-Depth Render Element is useful for adding depth of field to the final image in post production using a compositing application without the need for re-rendering. It can also be used to create basic fog by overlaying it on the composite with Add mode or Screen mode, with color correction as needed.
Section | |||||||||||||||||||||||||||||||||||||
