width60%
V-Ray includes a set of lights designed specifically for rendering with the V-Ray engine.
Depending on the scene and the effect you are trying to create with light, you might choose to use only one type of light or any combination of lights.
Below you can find detailed information on creation, application and UI functionalities of the different V-Ray lights.
UI Expand
titleUI Path: ||obj Network|| > V-Ray > Light
||V-Ray Shelf||
width5%
width35%
HTML
<iframe width="560" height="315" src="https://www.youtube.com/embed/Uk30LomkQnY" title="Lighting your scenes in V-Ray for Houdini" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" referrerpolicy="strict-origin-when-cross-origin" allowfullscreen></iframe>
Image Removed
Light Types
The  following light types can be created with V-Ray for Houdini:
