This section provides an overview of Cameras in V-Ray for Houdini.
width55%
V-Ray makes full use of regular Houdini cameras, but can also add attributes for more advanced functionality.
UI Text Box
typetip
You can project a texture from a specific camera with V-Ray for Houdini. To do so, set the texture mapping type to Projection. Then link the specific camera to the Projection Camera field of the texture.
If you are projecting a texture from a camera in Solaris, link the specific camera to the Projection Camera (LOP) field. For more information, see the Solaris Camera Settings page.
Expand
titleClick here to expand an example.
Image Modified
width5%
width40%
HTML
<iframe width="560" height="315" src="https://www.youtube.com/embed/RE4UYfRozI4" title="Working with camera settings and lens effects in V-Ray for Houdini" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" referrerpolicy="strict-origin-when-cross-origin" allowfullscreen></iframe>
Overriding Camera Properties
