Example: Use Triplanar Mapping
This examples shows the effect of the Use Triplanar Mapping option. The Tiling Factor is set to 20. The .vrscan material used for the example is Metal matte rust.
Section | |||||||||
Example: Tiling Factor
This example shows the effect of the Tiling Factor parameter. The .vrscan material used for the example is Metal matte rust.
Section | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
