Section | |||||||||||||||
Section | |||||||||||||||||||||||||||||||||||||
Example: Ignore Bump
In this example, a V-Ray Material with a wooden texture is applied to the geometry's diffuse slot. The Coat Color is set to black, the Coat Glossiness to 0.0 and a V-Ray Curvature map is linked to the Coat Amount parameter. The Curvature map's mode is set to Concave, the rest of its properties are left at their default state.
