To access the render elements used in a .vrimg or .exr image rendered on Chaos Cloud, you need to open the VFB and load the image you downloaded from Chaos Cloud rendering using the Load image ( ) option from the File menu. Once the image has loaded, you can use the drop-down menu on the uppermost left-hand side to scroll through all available render elements in your scene.
