This page provides information on the native Unreal Materials and Material Instances.
Floatingpagetoc |
Section | |||||||||||||||
Supported Expressions
Below are listed the expressions in the Material Editor that are supported by V-Ray for Unreal.
UI Text Box | ||
Native Unreal Materials are supported in Hybrid rendering. Make sure you meet the System Requirements. |
Section |
UI Text Box | ||
If the Coordinate Index in the TextureCoordinate node in a material is set to a certain value and the material is applied to a Static mesh that doesn't have a corresponding UV channel, then that mesh will not render correctly in V-Ray. For example, the Coordinate Index in a material that is applied to a static mesh is set to 3 but the mesh has only 2 UV channels then the render result will be inaccurate. |
Supported Material Inputs, Blend Modes and Shading Models
Below are listed all inputs, Blend modes and Shading models in the Material Editor that are supported by V-Ray for Unreal.
Align | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Align | |||||
Align | |||||
Align | |||||
