Comment: removed TOC
This page is about render elements in V-Ray for Unreal.
Floatingpagetoc
Responsivegridmacro
VAlignmentstart
Columns2repeat(2, 1fr)
Columns3width1100px
Columns1repeat(3, 1fr)
Columns1width1740px
Columnsrepeat(4, 1fr)
Columns2width1290px
width45%
Render Elements are a way to break out renders into their component parts such as diffuse color, reflections, shadows, mattes, etc. This gives fine control over the final image when using compositing or image editing applications when re-assembling the final image from its component elements.
Render Elements are generated at render time based on the ones you choose before rendering. Most render elements have parameters that can be set to customize the render element or its later use in compositing software.
They are accessible from the V-Ray Settings menu.
width5%
width50%
Denoiser – A render element that progressively applies a denoising operation to the image. The denoising operation detects areas where noise is present and smooths them out.
None – No render element will be generated.
V-Ray Denoiser – V-Ray's denoising algorithm.
NVIDIA AI Denoiser – V-Ray's integration of NVIDIA's AI-based denoising algorithm. The NVIDIA AI denoiser requires an NVIDIA GPU to work.
VRay Render Presets
Each preset group of channels can be activated for render by ticking the Enable option.
Div
stylepadding-left: 5px;padding-right: 5px;padding-bottom: 10px;
classdashboard
Textboxcard
CardTooltipClick to open the Beauty render elements page.
PageToIncludeSystem Requirements
CardPageLinkBeauty render preset
Beauty
The Beauty Render Elements are the primary render elements that form V-Ray's pre-composited final render Beauty (RGB_Color) image.
Textboxcard
CardTooltipClick to open the Filters render preset page.
CardPageLinkFilters Render Preset
Filters
Shows only the selected set of channels in the render, disregarding any backgrounds, textures, etc.
Textboxcard
CardTooltipClick to open the Masks render preset page.
PageToIncludeInstallation
CardPageLinkMasks Render Preset
Masks
Provides a variety of Render Elements to be used as masks in the compositing process.
Textboxcard
CardTooltipClick to open the Light Mix render element page.
CardPageLinkLightMix Render Element
LightMix
Provides adjustment control to the lights in the scene from inside the New V-Ray Frame Buffer.
Textboxcard
CardTooltipClick to open the Cryptomatte render element page.
PageToIncludeGetting Started
CardPageLinkCryptomatte Render Preset
Cryptomatte
Uses the Cryptomatte convention by Psypop to encode mattes (Node Names, Material names) into multichannel OpenEXRs.
Textboxcard
CardTooltipClick to open the Coordinates render preset page.
CardPageLinkCoordinates Render Preset
Coordinates
The Coordinates Render Elements are based on the scene geometry that serve different purposes.
Textboxcard
CardTooltipClick to open the Light select render preset page.
CardPageLinkLight Select Render Preset
Light Select
Stores direct lighting information from user-selected lights in the scene; can also be limited to the light's raw, diffuse, or specular contribution.
Textboxcard
CardTooltipClick to open the Utility render preset page
CardPageLinkutility render preset
Utilities
This group of Render Elements can be used for troubleshooting purposes.
Textboxcard
CardTooltipClick to open the Custom render preset page
CardPageLinkCustom Render Element
Custom
You can add any of the render channels again from the Custom option, allowing you to use it with a different setup.
