This page offers a tutorial on how to set custom data as UVs in V-Ray for Houdini.
In Houdini you can use two types of data as UV coordinates for textures – those are the Float and Color attributes. They can be used directly or adjusted in the shader.
In this tutorial we'll show both ways.
To download scene files:
UI Button | ||||||||
Want to follow along but don’t have a license?:
UI Button | ||||||||||
Float Data as UV Coordinates
Section | |||||||||||||||||
These steps are enough for V-Ray to display a texture in the final render.
The 4-th frame rendered.
Change the v coordinate value to see the change in the render.
Color Data as UV Coordinates
Now V-Ray can display a texture in the final render.
And here is the resulting render.
