V-Ray for Houdini
tachments (25)
V-Ray for Houdini Help
Tutorials
Old Version
31
changes.mady.by.user
Gergana Lilkova
Saved on
Jun 23, 2021
compared with
New Version
32
Gergana Lilkova
Saved on
Nov 03, 2021
Previous Change: Difference between versions 30 and 31
Next Change: Difference between versions 32 and 33
View Page History
This line was added.
This line was removed.
Formatting was changed.
width
4%
width
30%
Thumbnail
ThumbnailTitleText
Material Presets in V-Ray for Houdini
ThumbnailBGImage
ThumbnailSubText
Information about the Material Presets in V-Ray for Houdini
ThumbnailPageLink
https://docs.
chaosgroup
chaos
.com/display/VRAYHOUDINI/Material+Presets+in+V-Ray+for+Houdini
width
1%
width
30%
Thumbnail
ThumbnailTitleText
Adding Displacement to Object
ThumbnailBGImage
ThumbnailSubText
How to set displacement to an object.
ThumbnailPageLink
https://docs.
chaosgroup
chaos
.com/display/VRAYHOUDINI/Adding+Displacement+to+Object
width
1%
width
30%
Thumbnail
ThumbnailTitleText
Custom Data as UV Coordinates
ThumbnailBGImage
ThumbnailSubText
How to set custom data as UVs in V-Ray for Houdini
ThumbnailPageLink
https://docs.
chaosgroup
chaos
.com/display/VRAYHOUDINI/Custom+Data+as+UV+Coordinates
width
4%
width
4%
width
30%
Thumbnail
ThumbnailTitleText
Projection Baking with V-Ray
ThumbnailBGImage
ThumbnailSubText
How to use V-Ray BakerTool or V-Ray Renderer ROP for projection baking.
ThumbnailPageLink
https://docs.
chaosgroup
chaos
.com/display/VRAYHOUDINI/Projection+Baking+with+V-Ray
width
1%
width
30%
Thumbnail
ThumbnailTitleText
ACEScg Workflow Setup
ThumbnailBGImage
ThumbnailSubText
The proper ACEScg color space workflow with V-Ray 5 for Houdini
ThumbnailPageLink
https://docs.
chaosgroup
chaos
.com/pages/viewpage.action?pageId=66687648
width
1%
width
30%
width
4%
width
4%
width
30%
Thumbnail
ThumbnailTitleText
HQueue and V-Ray
ThumbnailBGImage
ThumbnailSubText
How to set up a render farm using HQueue and V-Ray
ThumbnailPageLink
https://docs.
chaosgroup
chaos
.com/display/VRAYHOUDINI/HQueue+and+V-Ray
width
1%
width
30%
width
1%
width
30%
width
4%
