Color – Specifies the base color that is corrected using OCIO.
Input/Output Section – Determines how the input and output color spaces are specified.
By Color Space – The user specifies the input and output color spaces directly. By Role– The user specifies the input and output color space depending on the task that they want to perform as defined in the OCIO configuration.
ConfigurationSource – Manually specifies an OCIO configuration. If not specified, the OCIO environment variableis used.
Config File – Specifies the OCIO configuration file.
Mode – Specifies what color transformations are performed:
ColorSpace – The texture performs color space conversions. CDL Transform – The texture performs an ASC CDL transformation. CDL stands for "Color Decision List", which is a color grading information exchange format developed by the ASC (American Society of Cinematographers). File Transform – The texture performs a color transformation based on another file (i.e. .3dl, .lut, .cube, etc.). LogConvert – The texture performs log2lin or lin2log conversion. Display – The texture performs color space conversion for display. Look – The texture performs a look transform. The OCIO config must define looks for this mode to work.
