UI Text Box | ||
Тo use NVLINK on supported hardware, NVLINK devices must be set to TCC mode. This is recommended for Pascal, Volta and Turning-based Quadro models. For GeForce RTX cards, a SLI setup is sufficient. Also note that to prevent performance loss, not all data is shared between devices. For more information, see the OptiX and NVLink FAQ. |
Anchor oclDeviceSelect oclDeviceSelect
