This page provides information on setting up V-Ray GPU.
Section | ||||||||||||||||
Supported Hardware and Drivers
Fancy Bullets | ||
Rendering on multiple GPUs is supported and by default V-Ray GPU uses all available CUDA devices. See the sections below for information on how to choose devices to run V-Ray GPU on.
If V-Ray GPU cannot find a supported GPU device on the system, it silently falls back to CPU code. To see if the V-Ray render server is really rendering on the GPU, check out its console output.
You may not want to use all available CUDA devices for rendering, especially if you have multiple GPUs and you want to leave one of them free for working on the user interface or you may want to combine your CPU and GPU together (see Hybrid Rendering section below). To do this, you can use the GPU Devices menu in the Export tab of the V-Ray Renderer node.
After changing this option, you need to restart the V-Ray render server (if it is running) for the changes to take effect. If the V-Ray render server is running as a Windows service, you may need to stop it from the Services applet in the Control Panel.
Balancing the GPU Load
If you have only one GPU on your system, you may find that the user interface becomes sluggish and unresponsive while IPR is rendering on the GPU. To alleviate this problem, reduce the Max. Paths Per Pixel and/or enable the Low GPU thread priority option in the Rendering section of the Renderer > IPR tab of V-Ray Renderer node. This breaks up the data passed to the GPU into smaller chunks so that the user interface requests can be processed faster. Note, however, that this reduces the rendering speed. Turn on the statistics display to check the difference in render speed and to find the optimal settings for your system.
Anchor | ||||
Hybrid Rendering with CPUs and the CUDA Engine
