Name – The text added to the end of the rendered file, when saved as a separate file (e.g. myrender.lightselect.vrimg).
Anchor
Mode
Mode
Type– Sets what type of lighting contribution is generated in the element as follows:
Direct Illumination – Lighting within the Light Select element behaves as normal and contains diffuse and specular information. Direct Raw – Lighting within the Light Select element behaves as a raw render element. Direct Diffuse – Lights within the Light Select element output only their diffuse contribution and contain no specular information. Direct Specular – Lights within the Light Select element output only their specular contribution and contain no diffuse information. Full – Lights within the VRayLightSelect element provide full output for all information available in the scene such as GI, SSS, reflection, refraction, etc. Indirect – Lights within the VRayLightSelect element output only the indirect scene lighting. IndirectDiffuse – Lights within the VRayLightSelect element output only indirect scene lighting that originated from the diffuse contribution of the specified lights. IndirectSpecular – Lights within the VRayLightSelect element output indirect scene lighting that originated from the specular contribution of the specified lights. Light Path Expressions – Allows capturing custom light transport paths with regular expressions.
LPE – Specifies a light path expression (LPE) string based on the OSL syntax. It can be used to filter certain light contributions.
Lights – Selects which lights will be affected by the Light Select render element.
Color Mapping – Applies the color mapping options specified in the Color Mapping tab of the Renderer tab of the V-Ray Renderer node. This option is enabled by default.
Denoise – Enables the render element's denoising, if V-Ray Denoiser render element is present.
DeepOutput – Specifies whether to include this render element in deep images.
UI Text Box
type
info
The With V-Ray Next for Houdini the LPE is enabled by setting the VFH_LPE_ENABLE variable to 1. With V-Ray 5 for Houdini the LPE is enabled by default.
