UI Text Box
typenote
Assigning Object Properties SOP and/or Displacement materials works with packed geometry. It is not expected to work with packed fragments. See the V-Ray Object Properties SOP page.
UI Text Box
typetip
There are several approaches to adding the same object properties to multiple geometries:
  1. Add object properties individually to each geometry node;
  2. Add the object properties to a Subnetwork holding multiple geometry nodes;
  3. Use the V-Ray Renderer ROP > Objects tab to assign the object properties to the geometries;
  4. Use the V-Ray Object Properties SOP inside the Geometry node to target individual Packed Primitives or Packed Alembic primitives.
UI paths:
||Select object(s)|| > V-Ray Shelf > Object Props
