This page provides some details on how to get V-Ray Standalone up and running.
UI Button
colorblue
newWindowtrue
icondownload
titleDownload V-Ray Standalone
urlhttps://download.chaosgroup.com/?platform=47&product=47
Installing V-Ray
The V-Ray Standalone installer is pretty straightforward and easy to follow and can be downloaded from the V-Ray | Standalone Downloads section of the Chaos Group website (please make sure you use your login credentials to ensure access to the download links). Before installing V-Ray, make sure your computer meets the System Requirements for running V-Ray. If you would like a step-by-step guide, please check out the Installation of V-Ray Standalone page. If you run into any problems, please check out the Troubleshooting page.
If you need to create a single custom V-Ray installation that can be easily transferred and installed on multiple machines, please see the Portable Installation page.
Licensing V-Ray
Once V-Ray is installed you will want to make sure that your V-Ray license is properly configured. The Chaos License Quick Start Guide page includes everything you need to get V-Ray licensed and running properly.
