Tabs Container
directionhorizontal
Tabs Page
titleWindows
To install V-Ray Standalone, make sure your Windows account has administrative privileges and double-click the installer to run it:
To complete the installation follow these steps:
1. You are presented with the V-Ray licensing agreement. Please take a moment to review the agreement. Tick the I accept the Agreement checkbox. Click on Install to proceed with a standard V-Ray installation. If you need to customize the installation, click on Advanced.
width60%
width40%
Expand
titleClick here to see the Advanced installation options...
Directories
At this step you can adjust the installation directory. Please check if the default directory is correct.
Help make V-Ray even better – Participate in the improvement decisions for future version of V-Ray. No intelligence property is violated when agreeing to participate in the feedback program. Chaos does not gather scenes, assets, materials, etc. What Chaos receives is user preferences on just a few key render settings and the resulting render times. The point of this feature is to improve V-Ray's performance and the user experience. For more information, see the Chaos Telemetry page.
width60%
width40%
Licensing
Here you specify whether the V-Ray license server runs locally or on a separate machine.
Fancy Bullets
typecircle
  • If you select the Remote option you have to fill in the IP address of your V-Ray license server in the field Primary License Server. Please leave the port 30304 unchanged. An Alternate License Server is used when the primary one does not respond.
width60%
width40%
Fancy Bullets
typecircle
  • If you select the Local Licensing Option, you are presented with the Chaos License Server installation. At this step you can choose the license server directory.
Migrate data during installation – When enabled, the installer transfers all of your settings made with older versions of the License Server, such as enabled dongle subsystem, proxy settings, etc. Disabling this option installs the License Server with all settings at their defaults and any custom settings from the previous installation are be lost.
Add firewall exception –  Enabling this option allows the default licensing port (TCP 30304) in the firewall. If you disable it at this step, you need to manually add firewall exceptions later.
width60%
width40%
Once you are ready, click Install or Continue.
2. The installer proceeds to uninstall any previous versions and install V-Ray Standalone. If the installation is successful, the following window opens.
width60%
width40%
Click on Done
Tabs Page
titleLinux
To install V-Ray Standalone in Linux, follow these steps:
1. Unpack the contents of the installation archive to a temporary folder (for example vray_install_dir).
2. Open a console and navigate to the folder.
Code Block
languagebash
titleExample
$ cd vray_install_dir
3. Follow the instructions of the installer:
3.1 You are presented with the V-Ray licensing agreement. Please read carefully the agreement! Tick the I accept the Agreement checkbox. Click on Install to proceed with a standard V-Ray installation. If you need to customize the installation, click on Advanced.
width60%
width40%
Expand
Directories
width60%
width40%
Licensing
Fancy Bullets
typecircle
width60%
width40%
Fancy Bullets
typecircle
  • If you select the Local licensing option, you are presented with the Chaos License Server installation. At this step you can choose the license server directory.
Migrate data during installation – When enabled, the installer transfers all of your settings made with older versions of the License Server, such as enabled dongle subsystem, proxy settings, etc. Disabling this option installs License Server with all settings at their defaults and any custom settings from the previous installation is lost.
width60%
width40%
Click Install or Continue to proceed.
3.2 The installer proceeds to uninstall any previous versions and install V-Ray Standalone. If the installation is successful, the following window opens.
width60%
width40%
4.Click on Done.
UI Text Box
typewarning
 It may be necessary to log out and log in again so that some of the changes to the environment variables made by the installer can take effect.
Tabs Page
titlemacOS
To install V-Ray Standalone on Mac OS XmacOS, extract the V-Ray installation file in an appropriate folder and double click to run it.
1. You are presented with the V-Ray licensing agreement. Please read carefully the agreement! Tick the I accept the Agreement checkbox. Click on Install to proceed with a standard V-Ray installation. If you need to customize the installation, click on Advanced.
width60%
width40%
Expand
Directories
width60%
width40%
Licensing
Here you specify whether the V-Ray License Server runs locally or on a separate machine.
Fancy Bullets
typecircle
width60%
width40%
Fancy Bullets
typecircle
width60%
width40%
Click Install or Continue to commence the installation.
width60%
width40%
Click on Done.
UI Text Box
typewarning
