Include Page | ||||
This page provides information on setting up licenses for V-Ray Standalone.
Page Contents
Table of Contents maxLevel 2 style circle
V-Ray uses a floating licensing system and it can obtain licenses from V-Ray license server, running on any machine, which can be accessed through your network, or even over Internet. The access to the license server is done over TCP/IP protocol on port 30304. Make sure that your anti-virus or firewall software is not blocking the communication to the license server.
The V-Ray license server requires one or more dongles (hardware lock containing your licenses, similar to a USB flash drive) installed on the same machine to operate. You should receive your dongle(s) and information whether it is already reprogrammed with the necessary licenses from your reseller.
After the installation, please make sure that you have the necessary licenses as described in the V-Ray License Server Status section below.
If your dongle doesn't contain the necessary licenses, see the Dongle Reprogramming section.
Dongles are not node locked; they can be transferred without any restrictions between V-Ray license servers. This allows you to quickly set up a new license server after a computer failure or to move a dongle to different locations when necessary.
Starting and Stopping the V-Ray License Server
This section shows how to start and stop the V-Ray license server under the different operating systems. You need to have a machine with a V-Ray license server running and a dongle with licenses plugged in in order to run V-Ray.
Windows
If you have opted to register the V-Ray license server as a Windows service, it will start automatically on the next Windows boot and this icon will not be visible. If there is no dongle attached to the machine, it will still start as a service but you will not be able to access the web status page or use any licenses until you plug-in your dongle.
You can start a V-Ray license server from Windows Start > All Programs > Chaos Group > V-Ray License Server for x64 > Launch V-Ray license server
If Windows Firewall is enabled, you may get the message below. Select the Unblock option to allow connections to the V-Ray license server.
If the V-Ray license server starts successfully, you will get the V-Ray license server icon in the Windows System Tray:
To stop V-Ray license service, double click on it's icon in the Windows System Tray and then click Terminate V-Ray license service.
Mac OS X
If you registered the license server to run as a service during the installation, it will be registered as a start-up item by the installer. In that case, you can use the /sbin/SystemStarter command to start/stop the license server with the following commands in a Terminal window:
$ sudo /sbin/SystemStarter start vrlservice
$ sudo /sbin/SystemStarter stop vrlservice
If the license server is not registered as a service, then you can run it directly from its install location which by default is: /Applications/ChaosGroup/VRLService/snow_leopard_x86/bin. Make sure that the dongle is plugged in. Double-click the vrlservice application in Finder to run the license server. To stop the license server, right-click on its icon and choose Quit.
The V-Ray license server can be registered to automatically run at login. To do that start it manually, then right click on its icon and from the Options menu select Open at Login.
Linux
If you registered the license server to run as a service during the installation, it will be registered as a daemon by the installer. In that case, you can use the /etc/init.d/vrlsvcctl command to start/stop the license server with the following commands in a Terminal window:
$ /etc/init.d/vrlsvcctl start
$ /etc/init.d/vrlsvcctl stop
$ /etc/init.d/vrlsvcctl restart
If the license server is not registered as a service, then you can run it directly from its install location:
$ /usr/ChaosGroup/VRLService/linux_x64/bin/vrlservice
Make sure that the dongle is plugged in before running the license server.
The V-Ray license server has a web interface that allows you to check its status and available licenses. The license server must be running to view the status web page. Please open the link http://<IP_address>:30304/getstatus in a web browser, where <IP_address> is the IP address of the license server. For example:
http://10.0.0.100:30304/getstatus
The status page shows information about the total number of licenses available to the license server; how many of them are engaged and from which IP address they are engaged.
You have to make sure that you have V-Ray Render Node 3.0 licenses.
In the Licenses usage summary section, you can see information about the licenses on the license server. In the Total column you can see all the available licenses on the dongle; in the Engaged column you can see how many of the licenses are currently being used, and in the Free column you can see the number of the licenses that are currently free.
The Stored licenses details is useful when more than one dongle is plugged in the license server. Here you can see a summary of all available licenses and the serial number of the dongle on which they are placed. If the license has an expiration date this is also displayed. In the example below, you can see that we only have one dongle connected, the serial number of the dongle is 10552214 and it has one V-Ray Render Node 3.0 license which is non-expiring.
The Active sessions list shows the IP addresses of all computers currently connected to the license server and the types of licenses they are using.
The Global dongle expiration dates shows a list of all dongles plugged in the license server and their expiration dates (different from license expiration dates explained above). In the example below there is one dongle with serial number 10552214 and it does not have an expiration date.
If you do not see V-Ray Render Node 3.0 licenses, your dongle has to be reprogrammed as described in Dongle reprogramming section below.
If you can't access the V-Ray license server web page, please refer to the Troubleshooting page.
If you do not have the necessary V-Ray licenses on your dongle, it will have to be reprogrammed. Reprogramming a dongle is a two-part process:
Fancy Bullets | ||
Creating a .wbc File
Here we describe how to create a remote programing context file (.wbc) file, which identifies your specific dongle. If there are more dongles attached on the machine, the steps below will create one .wbc file containing information for all dongles. You need to have JavaScript enabled on your web browser.
Please open the link http://<IP_address>:30304/ upgrade in a web browser, where <IP_address> is the IP address of the license server. For example:
http://10.0.0.100:30304/upgrade
A web-based wizard will appear. Click on the link shown on the screenshot:
Wait until the remote context file is created.
When the Success! page appears, save the remote context file by right-clicking on the link and using Save Link As.../Save Target As...
Email this file to Chaos Group Support along with company and order information.
Updating the Contents of the Dongle
The support team at Chaos Group will use your .wbc file to generate one or more .rtu files and send them back to you. Each .rtu file is named with the serial number of the dongle that it is intended for. You can find the dongle serial number on its sticker.
Windows
When you receive the .rtu file, save it on the machine where the dongle with the same serial number is plugged-in.
If the V-Ray license server is running, stop it by double clicking its icon in the Task Bar and selecting Terminate V-Ray license service . If it is registered as a service you have to stop the V-Ray license server from Windows Control panel > Administrative tools > Services applet.
Double-click the saved .rtu file. You will be asked to confirm the transfer on the dongle. Click Yes to update your dongle. If there is a problem, please refer to the Updating dongles when .rtu files are not associated properly section on the Troubleshooting page.
Start the V-Ray license server from Windows Start > All Programs > Chaos Group > V-Ray License Server for x64 > Launch V-Ray license server or from the Services applet.
Mac OS X
- When you receive the .rtu file, save it on the machine where the dongle with the same serial number is plugged-in.
- If the V-Ray license server is running, stop it by right-clicking its icon selecting Quit. If it is registered as a service you have to stop the V-Ray license server from the Terminal with the following command:
- In Finder, navigate to the /Applications/WIBUKEY folder and start the WkConfig application. Select the Update tab and click on the Execute Update... button to browse for the .rtu file and update the dongle.
- Start the V-Ray license server.
Linux
When you receive the .rtu file, save it somewhere on the disk of the machine where the dongle is plugged.
Close the V-Ray license server, if it is running.
From a terminal window, enter the command:
$ wku REMOTE USB SET FROM <somefile.rtu>
where <somefile.rtu> is the name of the .rtu file you received from Chaos Group.
Start the V-Ray license server again.
After the dongle is reprogrammed, you can check if the new licenses have been added successfully as described in V-Ray License Server Status section.
V-Ray License Settings Change
If you are running the V-Ray license server on a different machine, you need to tell V-Ray Standalone where to look for it. This section describes how to do that on each operating system.
Windows
Run the V-Ray license client configuration utility from Windows Start > All Programs > Chaos Group > V-Ray Standalone for x64 > Change V-Ray Client license settings.
This will show you the window below, where you can specify the IP address of the machine that is running the V-Ray License Server. Please do not change the connection port that is set by default to 30304.
For example, if the license server machine has IP address of 10.0.0.100, you have to put that address in the License server field, under the tab Primary license server.
Mac OS X
Run the setvrlservice program from the /Applications/ChaosGroup/V-Ray/Standalone_for_snow_leopard_x64/bin/snow_leopard_x64/ directory, e.g:
/Applications/ChaosGroup/V-Ray/Standalone_for_snow_leopard_x86/bin/snow_leopard_x86/setvrlservice -server=[server name or IP] -port=30304
where [servername or IP] is the IP address or name of the machine where the V-Ray license server is running, without the enclosing bracket '[' and ']' characters (note that the entire command is just one line).
Note: This setting is per user; if there are many users running V-Ray for Maya on the machine, you will need to set the license server location for each of them.
Linux
Run the setvrlservice program from the /usr/ChaosGroup/V-Ray/Standalone_for_linux_x64/bin/linux_x64/ directory, e.g:
$ /usr/ChaosGroup/V-Ray/Standalone_for_linux_x64/bin/linux_x64/setvrlservice -server=[server name or IP] -port=30304
where [servername or IP] is the IP address or name of the machine where the V-Ray license server is running, without the enclosing bracket '[' and ']' characters.
