In this section you can find some common issues that may arise when working with V-Ray Standalone.If you encounter a problem that is not listed here or cannot be solved with the suggested solutions, please contact Chaos Group Support.
Cannot Install V-Ray
Symptoms:
The installation file crashes when you attempt to run it.
Cause:
The installation file is not downloaded properly.
Solution:
Please re-download the installation file from our web site.
V-Ray Could Not Obtain License
Here you can find the list of symptoms and their likely cause when V-Ray could not obtain the license. Please check the resolution part at the end of this section.
Symptoms:
When you try to render with V-Ray Standalone, an error message appears in the console: “Could not obtain a license (10061).”
Cause:
No access to the Chaos license server.
Symptoms:
When you try to render with V-Ray Standalone, an error message appears in the console: “Could not obtain a license (-98).”
Cause:
No available license on the Chaos license server.
Symptoms:
When you start the V-Ray GPU render server, there are no error messages in the V-Ray console, but when a job is sent to the V-Ray GPU render server there is an error in the console "Could not obtain a license (10061)."
Cause:
Symptoms:
When you start the V-Ray GPU render server, there are no error messages in the V-Ray console, but when a job is sent to the V-Ray GPU render server, the error in the console is "Could not obtain a license (-98)."
Cause:
Resolution:
Please go through the check-list below.
1. Checking the Chaos license server:
Please restart the machine with the Chaos license server and dongle installed. Unplug the dongle and plug it again in a different USB port, preferably USB 2.0. Make sure that Windows properly recognizes the dongle and doesn't show error message. If you receive an error message, please refer to License Server Can't Start section.
Start the Chaos license server from Windows Start menu > All Programs > Chaos Group > Start Chaos license server.
You may receive a message warning that the Chaos license server is already running.
Open the link http://localhost:30304 in a web browser on the same machine.
This will open the Chaos license server status web page. If it looks like the screenshot below, the license server is working.
2. Checking the available licenses on the license server: After you ensuring the Chaos license server is working, you need to check the available licenses. On the same machine, where the Chaos license server is running, open the link http://localhost:30304/getstatus
Please refer to Chaos License Server Status section in the Set up your V-Ray License page for more information on the type of licenses you need to look for.
If you do not see the V-Ray Standalone licenses, this means that your dongle has to be reprogrammed as described in Dongle reprogramming section in the Set up your V-Ray License page. If you don't see free licenses this means that all available licenses are in use and you can't have more concurrent users.
3. Checking the connection to the license server:
If V-Ray is on the same machine as the Chaos license server, you can skip this step.
To make sure that nothing is blocking the connection to the license server on the machine where you want to run V-Ray, open the link http://<IP_address>:30304 in a web browser, where <IP_address>is the IP address of the machine with the Chaos license server. If you get a web page like the one below, V-Ray can access the Chaos license server from this machine. In the example screenshot below the IP address of the machine with the license server is 10.0.0.160
If you get an error message that the web page can't be accessed then there is a network problem that prevents the connection to the Chaos license server. If you have any firewall or antivirus software running on your machines make sure they are not blocking applications' access to the network or blocking the communication on TCP/IP port 30304. Please contact your system administrator for more information.
4. Checking the V-Ray license settings:
On the machine where you want to use V-Ray, run the V-Ray license client configuration utility from Windows Start > All Programs > Chaos Group > Change license settings. In the dialog that appears, make sure that the IP address in the License server field at the Primary license server tab is entered correctly and that the connection port is 30304. If you modify any of these settings, you will need to restart V-Ray Standalone.
Note: If the Chaos license server is running on the same machine as V-Ray you can use localhost or 127.0.0.1 in the License server field.
Anchor
ServerCantStartWindows
Chaos License Server Can't Start
Symptoms:
When you start the Chaos license server it pops a dialog box like the one shown below:
Cause:
This error message appears when the Chaos license server cannot find a dongle attached to the machine.
Resolution:
Before you start, make sure the dongle is NOT plugged-in.
Uninstall the WIBU-KEY driver from Windows Control Panel.
Attach the dongle to a different USB port, preferably to USB 2.0. Make sure that Windows recognizes the dongle and doesn't show error messages. To verify that dongle is properly installed please go to the WindowsControl Panel > System applet. Choose the Hardware tab and then click on the Device manager button. Expand the Universal serial bus controllers list and check for a WIBU-BOX/RU entry there:
Dongle Disconnects Periodically
Symptoms:
The dongle is working for extended periods of time but periodically disappears for no apparent reason and is no longer detected by Windows as a USB device. This could cause the Chaos license server to fail or V-Ray licenses to be refused.
Cause:
There can be a number of reasons related to the hardware configuration and Windows settings like the Power options.
Resolution:
Please check your Windows Power Options, make sure that your USB devices are not powered off.
Try to plug the dongle into a different USB port on the same machine, preferably USB 2.0, and restart the Chaos license server. If you still experience problems, try to install it on a different machine.
Missing Chaos License Server Icon
Symptoms:
The Chaos licensing server is running but there is no icon in the Windows System Tray.
Cause:
The icon is hidden by the Auto-hide unused icons option of the Windows System Tray or the Chaos license server is registered as a Windows service.
Resolution:
If you have the Auto-hide unused icons option of the Windows System Tray, click on the double-arrow icon to expand the full list of icons.
If you still do not see the Chaos licensing service icon, that means that the V-Ray licensing service is started as a Windows service and in that case it cannot show any graphical user interface. There is currently no resolution for this; you need to manage the Chaos license service from the Windows Control Panel > Administrative tools > Services applet.
Updating Dongles when the .rtu Files are not Associated Properly
Symptoms:
WIBU-KEY drivers are properly installed, but double-click on the .rtu file doesn't update the dongle.
Cause:
The .rtu file is not associated properly with the WIBU-KEY drivers.
Resolution:
Please, first try the steps from the Chaos License Server Can't Start section. If this doesn't help proceed with the steps below:
Make sure that the dongle is plugged-in.
In the Windows Control Panel locate the WibuKey management tool and run it:
Now you need to start the Advanced Mode from the system menu by right-clicking onto the title bar. Go to the WibuBox Update tab.
Click Browse, specify the .rtu file, and press Apply.
V-Ray GPU is Crashing
Symptoms:
When rendering with V-Ray GPU on CUDA, it crashes without showing a specific error message.
Cause:
The scene you are trying to render is too large and the Graphics card memory is insufficient.
Resolution:
You can try to reduce the scene size by reducing the polygon count or by using lower resolution textures. V-Ray GPU has an option called Resize textures for GPU that you can use to automatically resize textures during rendering on the GPU.
Alternately you can upgrade your graphics device with one containing more memory.
Tabs Page
title
Multiexcerpt
MultiExcerptName
WindowsDump
Crash Dump Files Creation
If your V-Ray application crashes, a crash dump file, containing essential information about the causes of the crash is created. Its default location is in the temporary folder %temp%.
In case the crash dump file is missing from the temporary folder, you can create it manually. To do so, open the standard Windows Task Manager from the Start Menu. Then, right-click on the V-Ray application in the Processes tab to select the Create dump file option, while V-Ray app is crashed.
Image Removed
The crash dump file is created in the temporary folder.
Image Removed
If you are rendering with V-Ray Standalone and the app crashes, the dump file contains information about the crash process of V-Ray Standalone.
If rendering with V-Ray plugin in another application (3ds Max, Maya, etc.), the crash dump files contain information about both the V-Ray plugin processes and the host application processes.
Send the crash dump file and the build version of the application to the Chaos Group Support (support @ chaosgroup . com) for further resolution.
Tabs Page
title
Mac OS X
Mac OS X
MAC OS X
V-Ray Could not Obtain License
Symptoms:
Cause:
Symptoms:
Cause:
Symptoms:
Cause:
Symptoms:
Cause:
Resolution:
Please go through the check-list below:
Please restart the machine with the Chaos license server and dongle installed. Unplug the dongle and plug it again in a different USB port, preferably USB 2.0. Make sure that the operating system properly recognizes the dongle.Make sure that the Chaos license service is running, if you have issues refer to the Chaos License Server Can't Start section.
Open the link http://127.0.0.1:30304 in a web browser on the same machine.
Image Added
2. Checking the available licenses on the license server: After you ensuring the Chaos license server is working, you need to check the available licenses. On the same machine, where the Chaos license server is running, open the link.
Please refer to the Chaos License Server Status section in the Set up your V-Ray License page for more information on the type of licenses you need to look for. If you do not see the V-Ray licenses, this means that your dongle has to be reprogrammed as described in the Dongle reprogramming section in the Setting up your Licenses page. If you don't see free licenses this means that all available licenses are in use and you can't have more concurrent users.
3. Checking the connection to the license server: If V-Ray is on the same machine as the Chaos license server, you can skip this step. To make sure that nothing is blocking the connection to the license server on the machine where you want to run V-Ray, open the link http://<IP_address>:30304 in a web browser, where <IP_address>is the IP address of the machine with the Chaos license server. If you get a web page like the one below, V-Ray can access the Chaos license server from this machine. In the example screenshot below the IP address of the machine with the license server is 10.0.2.89
Image Added
MAC OS X
In this section you can find some common issues that may arise when working with V-Ray Standalone. If you encounter a problem that is not listed here or cannot be solved with the suggested solutions, please contact Chaos Group Support.
Symptoms:
Cause:
Symptoms:
Cause:
Symptoms:
Cause:
Symptoms:
Cause:
Resolution:
Image Removed
2. Checking the available licenses on the license server: After you ensuring the Chaos license server is working, you need to check the available licenses. On the same machine, where the Chaos license server is running, open the link. http://127.0.0.1:30304/getstatus Please refer to the Chaos License Server Status section in the Set up your V-Ray License page for more information on the type of licenses you need to look for. If you do not see the V-Ray licenses, this means that your dongle has to be reprogrammed as described in the Dongle reprogramming section in the Setting up your Licenses page. If you don't see free licenses this means that all available licenses are in use and you can't have more concurrent users.
Image Removed
4. Checking that the license server settings are correct. In the Terminal run the following:
This will show you the IP address or the name of the computer that V-Ray is trying to connect to; If it's incorrect refer to V-Ray license settings change in V-Ray configuration section.
Anchor
ServerCantStartMac
ServerCantStartMac
Symptoms:
When you start the Chaos license server it pops up and closes.
Cause:
Resolution:
Before you start, make sure that the dongle is plugged-in directly in the machine and try again. If it is still not working, follow the below steps:
Attach the dongle to a USB port DIRECTLY on your machine, preferably a USB 2.0. Make sure that the operating system recognizes the dongle and doesn't show error messages. To verify that dongle is properly installed, navigate to the following:
/Applications/ WIBUKEY/WkConfig.app
Tabs Page
title
multiexcerpt
Linux
MultiExcerptName
MacDump
If your V-Ray application crashes, crash dump files, containing essential information about the causes of the crash, are created.
The crash dump files are stored either in the /Library/Logs/DiagnosticReports (system-wide) or ~/Library/Logs/DiagnosticsReports (user-wide) directories, depending on the type of the process that has led to the crash.
Another crash dump file named core.<pid> (where <pid> stands for the PID of the crashed process) must be created in the /cores directory. In order to create this second crash dump file, activate the full core dumps via the ulimit -c unlimitedcommand which makes the core dump files size unlimited. Also make sure to have write permissions for the /cores directory.
In case the /cores directory is hidden in Finder, you can show the hidden files via the defaults write com.apple.finder AppleShowAllFiles TRUE command.
Send both the *.crash files and the crash dump file from the /core directory along with the build version of the V-Ray Standalone app to Chaos Group Support (support@chaosgroup.com).
If rendering with V-Ray Standalone and the app crashes, the dump files contain information about the crash process of V-Ray Standalone. If rendering with V-Ray plugin in another application (Maya, Houdini, etc.), the crash dump files will contain information about both the V-Ray plugin processes and the host application processes.
Tabs Page
title
Linux
Linux
Symptoms:
Cause:
Symptoms:
Cause:
Symptoms:
Cause:
Symptoms:
Cause:
Resolution:
Please restart the machine with the Chaos license server and dongle installed. Unplug the dongle and plug it again in a different USB port, preferably USB 2.0. Make sure that the operating system properly recognizes the dongle. Make sure that the Chaos license service is running. Open the link http://127.0.0.1:30304 in a web browser on the same machine. This will open the Chaos license server status web page. If it looks like the screenshot below, the license server is working.
Image Added
Please refer to the Chaos License Server Status in the Setting up your Licenses page for more information on the type of licenses you need to look for. If you do not see the licenses, this means that your dongle has to be reprogrammed as described in Dongle Reprogramming on the Setting up your Licenses page. If you don't see free licenses this means that all available licenses are in use and you can't have more concurrent users.
Checking the connection to the license server: If V-Ray is on the same machine as the Chaos license server, you can skip this step. To make sure that nothing is blocking the connection to the license server on the machine where you want to run V-Ray, open the link http://<IP_address>:30304 in a web browser, where <IP_address>is the IP address of the machine with the Chaos license server. If you get a web page like the one below, V-Ray can access the Chaos license server from this machine. In the example screenshot below the IP address of the machine with the license server is 10.0.0.160.
Image Added If you get an error message that the web page can't be accessed, then there is a network problem that prevents the connection to the Chaos license server. If you have any firewall or antivirus software running on your machines, make sure they are not blocking applications' access to the network or blocking the communication on TCP/IP port 30304. Please contact your system administrator for more information.
In the Terminal run the following: /usr/ChaosGroup/V-Ray/Standalone_for_linux_x64/bin/linux_x64/setvrlservice -dump
This will show you the IP address or the name of the computer that V-Ray is trying to connect to. If it is incorrect, refer to the V-Ray License Settings Change on the Setting up your Licenses page.
Symptoms:
When you start the Chaos license server, it pops up and closes.
Cause:
Resolution:
Attach the dongle to a USB port on your machine, preferably a USB 2.0. Make sure that the operating system recognizes the dongle and doesn't show error messages. To verify that dongle is properly installed, please use the WibuKey WkConfig application.
Image Added
In the WibuBox field, you must see the serial number of your dongle. If you do not find this entry, try plugging the dongle into a different USB port
Linux
Symptoms:
Cause:
Symptoms:
Cause:
Symptoms:
Cause:
Symptoms:
Cause:
Resolution:
Checking the Chaos license server: Please restart the machine with the Chaos license server and dongle installed. Unplug the dongle and plug it again in a different USB port, preferably USB 2.0. Make sure that the operating system properly recognizes the dongle. Make sure that the Chaos license service is running. Open the link http://127.0.0.1:30304 in a web browser on the same machine. This will open the Chaos license server status web page. If it looks like the screenshot below, the license server is working. Image Removed Checking the available licenses on the license server: After you ensuring the Chaos license server is working, you need to check the available licenses. On the same machine, where the Chaos license server is running, open the link http://127.0.0.1:30304/ Please refer to the Chaos License Server Status in the Setting up your Licenses page for more information on the type of licenses you need to look for. If you do not see the licenses, this means that your dongle has to be reprogrammed as described in Dongle Reprogramming on the Setting up your Licenses page. If you don't see free licenses this means that all available licenses are in use and you can't have more concurrent users. Checking the connection to the license server: If V-Ray is on the same machine as the Chaos license server, you can skip this step. To make sure that nothing is blocking the connection to the license server on the machine where you want to run V-Ray, open the link http://<IP_address>:30304 in a web browser, where <IP_address>is the IP address of the machine with the Chaos license server. If you get a web page like the one below, V-Ray can access the Chaos license server from this machine. In the example screenshot below the IP address of the machine with the license server is 10.0.0.160. Image Removed If you get an error message that the web page can't be accessed, then there is a network problem that prevents the connection to the Chaos license server. If you have any firewall or antivirus software running on your machines, make sure they are not blocking applications' access to the network or blocking the communication on TCP/IP port 30304. Please contact your system administrator for more information. Checking that the license server settings are correct. In the Terminal run the following: /usr/ChaosGroup/V-Ray/Standalone_for_linux_x64/bin/linux_x64/setvrlservice -dump This will show you the IP address or the name of the computer that V-Ray is trying to connect to. If it is incorrect, refer to the V-Ray License Settings Change on the Setting up your Licenses page.
Symptoms:
Cause:
Resolution:
Attach the dongle to a USB port on your machine, preferably a USB 2.0. Make sure that the operating system recognizes the dongle and doesn't show error messages. To verify that dongle is properly installed, please use the WibuKey WkConfig application. Image Removed In the WibuBox field, you must see the serial number of your dongle. If you do not find this entry, try plugging the dongle into a different USB port.
Multiexcerpt
MultiExcerptName
LinuxDump
Core Dump Files Creation
If your V-Ray application crashes, core dump files, containing essential information about the causes of the crash, are created.
You should make the size of the core dump files unlimited via the ulimit -c unlimited command. If the core dump files are not disabled in any other way, this should be sufficient to create a core.<pid> dump file in the current working directory or in the /var/lib/systemd/coredump directory, if using systemd. Here, <pid> stands for the PID of the crashed process.
In case no core dump file has been created, the following configuration files must be checked based on the Linux distribution used:
(non-systemd GNU Linux distributions - CentOS 6.x and others): Make sure that there is either no /etc/sysctl.d/50-coredump.conf file or it has a valid configuration value for the kernel.core_pattern. If you are uncertain, just remove the line from the file. This action may require root access.
(systemd based GNU Linux distributions - CentOS 7, Fedora and others): Make sure that there is no limit for the storage in /etc/systemd/coredump.conf.d/custom.conf by confirming that the [Coredump] Storage=none configuration lines are not present.
If rendering with V-Ray Standalone and the app crashes, the dump files contain information about the crash process of V-Ray Standalone. If rendering with V-Ray plugin in another application (Maya, Houdini, etc.), the crash dump files contain information about both the V-Ray plugin processes and the host application processes.
Send the core dump files and the build version of the V-Ray Standalone app to the Chaos Group Support (support@chaosgroup.com)
