-numThreads=nnn – Sets the number of rendering threads. The default is 0 - automatic number of threads.
-profilerMode=0/1/2 –  Specifies –  Specifies the mode of the V-Ray Profiler:
The default is 0 - disabled.
-profilerFile="fileName" –  Specifies profilerOutputDir=\directoryPath\ - Specifies the output file directory for the V-Ray Profiler results. If the file name parameter is empty or the parameter is omitted, a new file will be created in the  the OS's default temp directory is used.
Input Files
-sceneFile="filename.vrscene" – Specifies the scene file to render.
