The Effects tab offers settings control over two volumetric effects - the Sphere Fade and the Aerial Perspective.
The Sphere Fade is a volumetric gizmo used to render just a small part of the scene by putting it in a special spherical locator.
The Aerial Perspective atmospheric effect simulates aerial perspective - the effect that the Earth atmosphere has on the appearance of objects that are viewed from a distance, and which is similar to fog or haze. The atmospheric effect works together with the VRaySun and the VRaySky V-Ray Sun and V-Ray Sky to calculate an approximation to the aerial perspective effect.Sphere Fade is a volumetric gizmo used to render just a small part of the scene by putting them in a special spherical locator.
UI Paths:
||out Network|| > V-Ray > V-Ray Renderer > Effects tab
