width40%
The instructions on this page will guide you in setting up a simulation that uses Maya nParticles as its Source object.
UI Button
colorblue
newWindowtrue
icondownload
titleDownload Free Trial
urlhttps://www.chaos.com/free-trial?utm_campaign=docs-tutorials&utm_medium=website&utm_source=docs.chaos.com
width60%
Steps
width40%
Create a Phoenix Simulator and a Phoenix Source.
Create an object to act as an emitter inside the Simulator.
Select the emitter object and go to nParticles → Emit from Object.
width60%
