These are small and simple tech demos showing different techniques. They are more complicated than the Toolbar Quick Setup presets but are simpler than the big Example Scenes.
UI Button
colorblue
newWindowtrue
icondownload
titleDownload Free Trial
urlhttps://www.chaos.com/free-trial?utm_campaign=docs-tutorials&utm_medium=website&utm_source=docs.chaos.com
Burning Forest
UI Button
colorblue
newWindowtrue
icondownload
titleDownload scene (1,48 MB)
urlhttps://drive.google.com/uc?export=download&id=1DD991iHsO3oTGMTVIVMvdX8eEr3WiNsX
Blending Three Materials
UI Button
colorblue
newWindowtrue
icondownload
titleDownload scene (204 KB)
urlhttps://drive.google.com/uc?export=download&id=1Yni-E0e4_YaUwCS6YSU4twcsfqofKz-W
width50%
Align
alignleft
The scene shows how you can blend three materials in one Phoenix Simulator. There are 3 different Phoenix Sources and each one has a different color for the RGB channel. There is 1 pure red, 1 pure green and 1 pure blue.
A Phoenix Grid Texture is used to read the Grid RGB data from the simulator. Then each color channel of the Phoenix Grid Texture (the red, the green and the blue) are used as masks in a V-Ray Blend Material with 3 different materials used as coats.
Water Sprinkler
UI Button
colorblue
newWindowtrue
icondownload
titleDownload scene (583 KB)
urlhttps://drive.google.com/uc?export=download&id=1oTZNUwl6RAwt5wL3gDQ7VvCnKMwYwpd_
width50%
Align
alignleft
The scene is using a very thin Phoenix Simulator and a small emitter cylinder inside a curved tube used to simulate a high pressure water system. In order for the fluid to be directed in a specific direction the Source is using an Emit Material that is placed on one of the faces of the emitter. Everything is set in real scale so it should fit in any project when imported - approximately 10 meters wide and 1,5m. in height.
Additionally the effect is enhanced by V-Ray Environment Fog under the water arc.
Honey Bubbles
UI Button
colorblue
newWindowtrue
icondownload
titleDownload scene (112 KB)
urlhttps://drive.google.com/uc?export=download&id=1MKjWJzEOFzrCRiEo22idovLLks42CcHx
Droplets on a windshield
UI Button
colorblue
newWindowtrue
icondownload
titleDownload scene (108 KB)
urlhttps://drive.google.com/uc?export=download&id=1u2zTXN43e_x1kw3PceILzUKOUg4-BfGz
width50%
Align
alignleft
The box is used as an emitter and for the Source's Discharge there are two noise textures used as a mask to randomize the emission and create small and big droplets.
In the Dynamics rollout the Surface Tension to 1 so that the liquid can be accumulated in a bigger drops while travelling downwards and a Droplet Formation of 0.4 is set so that droplets can be formed. The Wetting is turned on and some Sticky Liquid is added in order for the drops to stick to the surface.
As we want some drops to stay stationary and some to fall dawn there is a Phoenix Mapper node added which sets the Viscosity for the Grid to 0.2. As this works on the whole grid a noise texture is added as a mask so only some parts will be affected by the Mapper and the rest will not.
Droplet Splash
UI Button
colorblue
newWindowtrue
icondownload
titleDownload scene (92 KB)
urlhttps://drive.google.com/uc?export=download&id=14VPzCeVwzLIBQbT0RAR1KTlzgzWUoZf9
Body Force Text Fill up
UI Button
colorblue
newWindowtrue
icondownload
titleDownload scene (203 KB)
urlhttps://drive.google.com/uc?export=download&id=1XXmcorZ_k8RWOPXHAtP1uQPG2thjxNoX
Liquid Cascade simulation
UI Button
colorblue
newWindowtrue
icondownload
titleDownload scene (149 KB)
urlhttps://drive.google.com/uc?export=download&id=1M158odrw0OdIQGMJ4P_f7TWsH30gDqGU
Fire/Smoke Cascade simulation
UI Button
colorblue
newWindowtrue
icondownload
titleDownload scene (106 KB)
urlhttps://drive.google.com/uc?export=download&id=1Cnvdg-2OZxXM4d4WHyheawmB7VIPz-m_
width50%
Align
alignleft
The scene shows cascading setup between two simulators. The Phoenix Source clamps the texture values between 0-1 so smoke and fuel will naturally transition fine, but temperature which goes above 1 - up to several thousand Kelvin - will need to be remapped before being plugged into the source. This is why the Remap value map is added after the grid texture reading the temperature channel and remapping it in the 0 to 1 range.
- You need to enable Motion Velocity on the Brush source so that the velocities will be transferred as well and of course you need to have velocity exported from the first sim.
- The area which overlaps will be rendered twice, unless you put a box as a render cutter for the first sim.
- Grid-based self-shadowing won't work between the cascade grids - you need to switch to the slower but more robust Ray-Traced self-shadowing.
Wind Tunnel
UI Button
colorblue
newWindowtrue
icondownload
titleDownload scene (134 KB)
urlhttps://drive.google.com/uc?export=download&id=1_-UvUpHVRntvYj8fShia8BQaGmoyvSPm
Smoke color by age
UI Button
colorblue
newWindowtrue
icondownload
titleDownload scene (117 KB)
urlhttps://drive.google.com/uc?export=download&id=1yRlAkMOOro13AiK8dXMWIbeWYJJPsh6R
Gas stove flames
UI Button
colorblue
newWindowtrue
icondownload
titleDownload scene (141 KB)
urlhttps://drive.google.com/uc?export=download&id=1x3-Cy9qWWqewaQm9ZocZwMbScE1NOnpM
width50%
Align
alignleft
This scene consists of a very simple setup: a Simulator, emitting geometry and a Fire Source. The emissive geometry is an extruded star spline that emits through polygons with the same material. This material is used as an input of the Emit Material option in the Fire Source. Of course, there are plenty of other methods to achieve this result (radial array of smaller geometries for example).
Tweaking of the following options has a significant impact on the final simulation’s result:
Discharge value in the Source;
Grid Resolution - for this kind of a scene it's pretty low;
Cooling - more cooling leads to shorter flames;
Steps Per Frame - high values produce smoother flames;
Volumetric Options - tune the flame's color, light emission, shape and a lot more from here.
Hot steam
UI Button
colorblue
newWindowtrue
icondownload
titleDownload scene (115 KB)
urlhttps://drive.google.com/uc?export=download&id=1rE_PjDyR0hJY9ImMfxGtceKvjd0ncjls
Smoke Inside of Text
UI Button
colorblue
newWindowtrue
icondownload
titleDownload scene (2 MB)
urlhttps://drive.google.com/uc?export=download&id=1e1_BNkj7Htlrk8v13UgLDRmm2R2vcRU3
Colorful Particle Explosion
UI Button
colorblue
newWindowtrue
icondownload
titleDownload scene (125 KB)
urlhttps://drive.google.com/uc?export=download&id=1K-4NjAsCdCbYXtZOdWUNnq9QgFHIGb83
