Info |
Example $ su |
The uninstaller will not remove the V-Ray license configuration files or any other files that you have modified manually after the installation.
MacOS
To uninstall Phoenix for Maya double-click the uninstaller.app program, which is normally located in /Applications/ChaosGroup/PhoenixFD/Maya20xx -x64/uninstall
This will start the Phoenix uninstaller. Follow the on-screen instructions to remove Phoenix from your system and restore any files overwritten by the installation.
Viewtracker | ||||
