HideElements
cssselector#tocVertical, #tocHorizontal
This page provides information on uninstalling Phoenix.
When installing Phoenix, the installer will automatically uninstall any previous versions by default. The following steps can be taken to manually uninstall Phoenix.
Windows
Before uninstalling Phoenix, make sure that Maya or Phoenix components are not being used. Then go to either of the following:
This will start the Phoenix uninstaller. Follow the on-screen instructions to remove Phoenix from your system and restore any files overwritten by the installation.
Linux
To uninstall Phoenix for Maya, start with root permissions the uninstall_chaos program, which is normally located in the /usr/ChaosGroup/PhoenixFD/MayaNNNN-x64/uninstall/ directory:
The uninstaller will not remove the V-Ray license configuration files or any other files that you have modified manually after the installation.
MacOS
To uninstall Phoenix for Maya double-click the uninstaller.app program, which is normally located in /Applications/ChaosGroup/PhoenixFD/Maya20xx -x64/uninstall
