width50%
License Server version 5.0 provides licensing of the Chaos Group products without the need for any physical devices to be plugged in your machine. It allows you to easily activate more licenses right after the purchase and provides a way to stay offline while using your products when you need to. It is still compatible with existing USB dongles, in case you need to use your licenses in this way.
width5%
width45%
Image Removed
Image Added
Interface
The License Server's interface is accessible in a web browser. See the License Server Interface page for more information.
To activate your licenses, go to 127.0.0.1:30304 using your web browser and click SIGN IN from the ONLINE LICENSING menu. You will then be prompted to enter your username and password. Once the activation is successful, you will be able to see the list of your available licenses on the License Server home page.
width20%
width60%
Image Added
width20%
Offline Activation and License Usage - Recommended for Machines Without Internet Access
width45%
You can still activate your License Server even without Internet connection. To do this you will need to download an an activation request file from your License Server. Use another machine with Internet connection to upload the file to my.chaosgroup.com where you log in with your Chaos Group account and generate an activation file. Upload the activation file to your License Server to activate it.
See also the Borrowing Licenses for Offline Use page for additional information.
width5%
width50%
HTML
<iframe width="560" height="315" src="https://www.youtube.com/embed/M9l2u0MO2uw?rel=0" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Expand
titleClick to expand for Offline Activation steps...
1) On the machine without Internet connection open License Server web interface the http://127.0.0.1:30304 page.
2) From the expandable menu of ONLINE LICENSING Online licensing, go to OFFLINE ACTIVATION. Image RemovedOffline activation.
width30%
width40%
Image Added
width30%
3) Press ACTIVATE OFFLINE Activate offline button.Image Removed
width30%
width40%
Image Added
width30%
4) Download your activation request file (cert.crs).
 Image Removed
width30%
width40%
Image Added
width30%
5) Use another machine with Internet connection to log in to my.chaosgroup.com with your Chaos Group account. Go to Licensing > License Servers and press Activate License Server.Image Removed
width30%
width40%
Image Added
width30%
6) Name your license server and press NEXT Next.
 Image Removed
width30%
width40%
Image Added
width30%
7) Upload the activation request file you downloaded in step 4 and press ACTIVATE.Image Removed Activate.
width30%
width40%
Image Added
width30%
8) Download your Activation file (cert.crt).Image Removed
width30%
width40%
Image Added
width30%
9) On the machine without Internet connection in your License Server web interface http://127.0.0.1:30304 page upload your Activation file (cert.crt) and press UPLOAD. Upload.
width30%
Image Removed
width40%
Image Added
width30%
10) Your site is now successfully activated.
width30%
width40%
Image Added
width30%
USB Dongle usage
The Licensing system allows you to use seats associated with your Chaos Group account easily from anywhere you can log into over the internet. If you also have a USB dongle with Chaos Group product licenses attached to your computer, you can utilize those available licenses with the License Server. For more details on this process, please see the Dongle usage page.
UI Text Box
typenote
The username and password credentials in the Change your license settings tool window are not the same as your online credentials used to log into your account at my.chaosgroup.com and activate version 5.0 of the License Server.
Image RemovedImage Added
