Access the Free Trial products
Go to www.chaos.com and press on the Try button in click Try in the upper right corner.
Section | |||||||||||||||
On the Free Trial page, select Stat Start your trial.
This takes you to the Chaos login page.
If you already have an account, you just need to sign in with your credentials.
If you do not have an account, press on click Create account, fill in your Email and create a Username and Password. Then press on the click Continue button.
Your account is ready to use. Press the Click Sign in button and and access with your credentials.
After signing in, you are directed to the following screen. Select your industry and role and press the click Continuebutton.
Select your primary tool of choice and your host platform and press on the click Continue button.
Next, you have to sign in to the License Server. Open the Manage Chaos License Server app. It automatically loads the License Server in a new webpage. Alternatively, enter 127.0.0.1:30304 in a browser. From the drop-down menu of Online licensing, press click Sign in and enter your credentials. The login credentials are the same you use to log in to chaos.com. Once you enter them, your License Server and Phoenix trial will be active.
