Motion Inertia | ext_wind, inert_mul – When enabled, moving the simulator object over a series of frames causes inertial forces in the opposite direction of the movement. This allows you to link the simulator to a moving object and keep the size of the grid relatively small, as opposed to creating a large grid that covers the entire path of the moving object. Motion Inertia can be used for moving ground and water vehicles, torches, fireballs, rockets, etc.
Div
style
margin-top: 10px
id
FireSmoke_Dynamics_Gravity
Gravity | grav, gmul, extgrav – Phoenix Gravity makes the liquids fall down and makes fire rise up. In fire/smoke simulations it creates velocities depending on the Temperature channel. In voxels where the Temperature is above 300 (in Kelvins, which is room temperature), Gravity will create upwards velocities. Where Temperature is below 300, the opposite will happen - velocities will be created pointing downwards. The hotter the fluid, the faster it will rise, and the cooler the fluid below 300, the faster it will fall down. The Gravity option is a multiplier, so using the default 1.0 will make it behave like real world gravity, setting it to 0.0 will disable its effect completely, and you can also use negative values, which will inverse the gravity effect.
Div
style
margin-top: 10px
id
FireSmoke_Dynamics_TimeScale
Time Scale |timescale – Specifies a time multiplier that can be used for slow motion effects. In order to achieve the same simulation look when changing the time scale, the Steps per frame value must be changed accordingly. For example, when decreasing the Time Scale from 1.0 to 0.5, Steps per frame must be decreased from 4 to 2. And of course, all animated objects in the scene (moving objects and sources) must be adjusted as well. Time Scaledifferent than 1 will affect the Buildup Time of Particle/Voxel Tuners and the Phoenix Mapper. In order to get predictable results you will have to adjust the buildup time using this formula: Time Scale * Time in frames / Frames per second
Div
style
margin-top: 10px
id
FireSmoke_Dynamics_Cooling
Cooling | cooling – This parameter controls the cooling of the fluid due to radiation. It gradually decreases the temperature until it reaches 300.
UI Text Box
type
info
Phoenix temperatures are in Kelvin, so 300 is room temperature - the temperature where the smoke neither ascends nor descends. A Cooling value of 1.0 corresponds approximately to the speed real smoke with a half thickness of 4 meters cools down. The real cooling is a very complicated process similar to the Global Illumination rendering, so here a simplified formula is used. You can find out more about Phoenix Grid Channel Ranges here.
Div
style
margin-top: 10px
id
FireSmoke_Dynamics_SmokeDissipation
Smoke Dissipation | smdiss – Used in simulations where the smoke needs to disappear, for example steam, clouds, etc. If you set this parameter to the maximum value of 1, the smoke will disappear immediately.
Anchor
SmokeBuoyancy
SmokeBuoyancy
Div
style
margin-top: 10px
id
FireSmoke_Dynamics_SmokeBuoyancy
Smoke Buoyancy | smoke_bcy – The buoyancy of the smoke. Positive values make the smoke move upwards. Negative values make it move downwards.
Div
style
margin-top: 10px
id
FireSmoke_Dynamics_FuelBuoyancy
Fuel Buoyancy | fuel_bcy – Specifies the buoyancy of the fuel.
width
5%
width
40%
width
55%
Anchor
AdvectionMethod
AdvectionMethod
Method | advtype – Specifies the algorithm used for calculating the advection. For more information, see the Advection Method Types example below.
Classic (Semi-Lagrangian) – This method has good stability, but does not strictly conserve the quantity of the transferred material and your fluid may start to gain or lose volume in certain situations. In such cases increasing the Steps per frame (SPF) will help preserve the volume. Forward transfer – Good conservation abilities, but less stability compared to the classic method. Tends to produce cross-like artifacts. Multi-Pass – This less dissipative method produces more fine details and keeps the smoke interface sharper compared to other methods. This method is recommended for large scale explosions, veil-like smoke, pyroclastic flows, and all other situations where sharpness is important. FLIP (Particle based) – Used for liquids.
Anchor
SPF
SPF
Steps per frame (SPF) | spf – Determines how many calculations the simulation grid will perform between two consecutive frames of the timeline. For more information, see the Steps per Frame example below.
UI Text Box
type
info
Steps per frame (SPF) is one of the most important parameters of the simulator, with a significant impact on quality and performance. To understand how to use it, keep in mind that the simulation is a sequential process and happens step by step. You cannot take a shortcut to simulate the last frame of a simulation, without first simulating all of the frames that come before it, one by one.
The simulation produces good results if each step introduces small changes to the sim.
For example, if you have an object that is hitting a liquid surface with a high speed, the result will not be very good if at the first step, the object is far away from the water, and at the second step, the object is already deep under the water. You need to introduce intermediate steps, until the object's movement becomes small enough that it happens smoothly across all steps for that frame.
The SPF parameter creates these steps within each frame. A value of 1 means that there are no intermediate steps, and each step is exported into the cache file. A value of 2 means that there is one intermediate step, i.e. each second step is exported to the cache file, while intermediate steps are simply calculated, but not exported.
UI Text Box
type
note
Increasing the Steps per frame (SPF) also comes with significant trade-offs to performance and detail.
A higher SPF decreases performance in a linear way. For example, if you increase the SPF twice, your simulation will take twice as long. However, quality does not have a linear relation to SPF.
For maximum detail, it is best to use the lowest possible SPF that simulates without any of the issues described in the tip box below, since each additional step kills fine details. For more information, please refer to the Phoenix Explained docs.
UI Text Box
type
tip
Signs that the Steps per frame (SPF) needs to be increased include:
Liquid simulations that have too many single liquid particles.
Liquid simulations that appear torn and chaotic.
Liquid simulations of streams that have visible steps or other periodical artifacts.
Fire/Smoke simulations with artifacts that produce a grainy appearance.
More often than not, these issues will be caused by the simulation moving too quickly (e.g. the emission from the source is very strong, or the objects in the scene are moving very fast). In such cases, you should use a higher SPF.
