The Simulation rollout contains the main panel for controlling the simulation process. It also displays statistical information like simulation times, and the content of the cache file for the current frame. The content can be grid channels such as Liquid, Velocity, etc., as well as particle groups. You can select which channels are exported to export to the cache files from the Output rollout, while particle groups are created by the Splash and Foam rollouts.
