UI Text Box
typetip
 UI Path: ||Select Liquid Simulator | LiquidSim object|| > Modify panel > Interaction rollout
width55%
Expand – Opens a floating dialog that contains the selected rollout and automatically folds the command panel rollout.
? – Opens up the help documents for the Liquid Interaction.
Include/Exclude List | ielist_newiemode_new – Determines which objects will be ignored or processed by the simulation. Use the radio buttons to switch between Include list and Exclude list. When Exclude list is active (the default), all objects in the scene will interact with the simulator unless they are added to the exclusion list. In Include list mode, no objects will interact with the simulator unless they are added to the list.
Exclude Hidden Objects | exclhidden_new – When enabled, the hidden objects will be excluded no matter if they are in the list or not.
Exclude Fire/Smoke Sims | exclfiresm  – When enabled, Fire/Smoke Simulators will not interact with the Liquid Simulator.
width5%
width40%
Image RemovedImage Added
