UI Path: ||Material Editor window|| > Material/Map Browser > Maps > PhoenixFD
Grid Texture
The Grid Texture reads from the simulation’s Grid Channels to generate a procedural texture, which can then be used to shade the simulation wherever colors are needed.
It can also be plugged into the texture slots of a material, and used to shade the meshes of simulated liquids that were exported with an RGB Grid Channel. It In addition, it can also be used as a blending mask, where the grid texture can read the RGB color of a simulator, which can then be used as a blending factor between two different materials.
Water textures are used with water effects to make them look more realistic.
Fancy Bullets | ||
UI Text Box | ||
Note that you can also use a Particle Shader to shade foam. |
Particle Texture
The Particle Texture can be used to read particles and color their positions.
