UI Text Box
typeinfo
The video below shows how to create and influence tP particles based on the data from Phoenix FD simulations.
Align
aligncenter
HTML
<iframe width="960" height="540" src="https://www.youtube.com/embed/qPOKh_iemB4" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
UI Text Box
typeinfo
The video below shows how to render Phoenix FD VDB caches with Redshift.
UI Text Box
typeinfo
 The video below shows how to render Phoenix FD VDB caches with Arnold.
Align
aligncenter
HTML
<iframe width="960" height="540" src="https://www.youtube.com/embed/ZwV30QgCVPM" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
UI Text Box
typeinfo
 The video below shows how to restore a Phoenix FD simulation.
Align
aligncenter
HTML
<iframe width="960" height="540" src="https://www.youtube.com/embed/DCzcXzRDd3o" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
UI Text Box
typeinfo
The video below shows how to run a Phoenix FD simulation using Autodesk Backburner.
Align
aligncenter
HTML
<iframe width="960" height="540" src="https://www.youtube.com/embed/sd_82WIka6E" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
UI Expand
titleSimulation with Autodesk Backburner
UI Steps
sizesmall
UI Step
Click the Phoenix FD Simulator → Output rollout → Set output cache file location.
UI Step
Start Backburner Manager, Server and Monitor.
Default Path: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Autodesk\Autodesk Backburner 20xx
UI Step
In the Backburner Monitor go to Manager → Connect manager and set the corresponding IP address.
UI Step
Click the Phoenix FD top menu → Submit Simulation to Backburner.
UI Step
Set the name or the IP address for the Backburner Manager.
UI Step
Turn on "Run only the Simulation and do Not Render".
UI Step
Press the "Run" button.
UI Text Box
typeinfo
 The video below shows how to use the Phoenix FD Wetmap.
Align
aligncenter
HTML
<iframe width="960" height="540" src="https://www.youtube.com/embed/o4oy1cRnHnY" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
UI Expand
titleUsing Phoenix FD Wetmap
UI Steps
sizesmall
UI Step
Click the Phoenix FD Simulator → Dynamics rollout → Enable "Wetting".
UI Step
Click the Phoenix FD Simulator → Output rollout → Make sure that the Wetmap particles are enabled for export.
UI Step
Open the Material editor and create two V-Ray materials.
UI Step
Create a V-Ray Blend Material and connect the already created V-Ray materials as Base color and Coat 1.
UI Step
Create a Phoenix FD Particle Texture → Select the Source Particle System → Select the Phoenix FD Simulator and pick the Wetmap particle group.
UI Step
Connect the Phoenix FD Particle Texture as a blend amount mask for the V-Ray Blend Material.
UI Step
Assign the V-Ray Blend Material to your geometry and render.
UI Text Box
typeinfo
The video below shows how to export a Phoenix FD cache to an Alembic file.
UI Expand
titleExporting the Liquid Mesh
UI Steps
sizesmall
UI Step
Set Phoenix FD Simulator → Export rollout → Export As: Mesh.
UI Step
Go to File → Export → Export Selected... (with the Phoenix FD Simulator selected).
UI Step
Under the Alembic Export Options dialog, make sure Extra Channels is set to UVW. Set the Animation → Range according to your needs.
UI Expand
titleExporting Particles
UI Steps
sizesmall
UI Step
Set Phoenix FD Simulator → Export rollout → Export As: Particles.
UI Step
Select the Phoenix FD Particle Group in the Scene Explorer and go to File → Export → Export Selected...
UI Step
UI Expand
titleImporting through a V-Ray Proxy
UI Steps
sizesmall
UI Step
Create a Standard Primitives → V-Ray → V-Ray Proxy and select the exported alembic file.
UI Step
When loading a sequence of Alembic files, you can use the "#" symbol as a hint to V-Ray that the file path is a sequence. "C;\alembic_0001.abc' becomes 'C:\alembic_####.abc".
UI Step
You can assign any V-Ray material to the imported alembic files.
In 3ds Max, while you have "Export as" set to "Mesh", the vertex velocity is in Map Channel 2 of the mesh, named "velocity". 3ds Max's built-in exporter names the Color Set in the exported Alembic file "Max_Map_Channel velocity".
Importing the Alembic file back into 3ds Max via the 3ds Max built-in Alembic importer requires you to set the "Velocity channel" to 2 in the V-Ray object properties dialogue, so you can render it with motion blur using V-Ray.
Importing the Alembic file in any host via VRayProxy will render with motion blur without any additional adjustments. It requires V-Ray Next Update 1.1, or newer.
UI Text Box
typenote
Importing the vertex velocity of the Alembic file into Maya using Maya's native importer (Cache → Alembic Cache → Import Alembic) is not supported.
UI Text Box
typeinfo
 This video shows how to use the Surface Texture option inside of Phoenix FD.
Align
aligncenter
HTML
<iframe width="960" height="540" src="https://www.youtube.com/embed/yLaqpjF4eUM" frameborder="0" allow="autoplay; encrypted-media" allowfullscreen></iframe>
UI Expand
titleTexture-Based Mesh
UI Steps
sizesmall
UI Step
Set Phoenix FD Simulator → Rendering rollout → Surface section drop-down to Texture.
UI Step
Click the No Map button and assign a texture (e.g. Cellular).
UI Step
Make sure that Phoenix FD Simulator → Preview rollout → Show Mesh is enabled. The generated mesh should now be visible in the Viewport.
UI Step
Tweak the Phoenix FD Simulator → Rendering rollout → Surface section → Isosurface Level parameter if necessary.
UI Expand
titleExporting OpenVDB
UI Steps
sizesmall
UI Step
Click the Phoenix FD Simulator → Output rollout → "..." button below the Simulation Cache Save Path option.
UI Step
Select Browse and navigate to a preferred folder. Set the File Name option and choose OpenVDB (*.vdb) from the Save As Type drop-down.
UI Step
Start the simulation as usual. The output cache files are now OpenVDB instead of AUR.
