UI Text Box
typeinfo
The video below shows how to use the Active Bodies to make a boat float and follow a predefined trajectory, reacting to the simulation automatically — without the need to create keyframes by hand.
UI Button
colorblue
newWindowtrue
icondownload
titleDownload Free Trial
urlhttps://www.chaos.com/free-trial?utm_campaign=docs-tutorials&utm_medium=website&utm_source=docs.chaos.com
Align
aligncenter
HTML
<iframe width="960" height="540" src="https://www.youtube.com/embed/FSCpwoaxCWY" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Anchor
ActiveBodiesFlood
ActiveBodiesFlood
How to wash away objects in a flood using Active Bodies
Align
aligncenter
HTML
<iframe width="960" height="540" src="https://www.youtube.com/embed/VibZZrH_ATM" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Anchor
renderTpParticles
renderTpParticles
How to render thinkingParticles using the Particle Shader and Particle Texture
Align
aligncenter
HTML
<iframe width="960" height="540" src="https://www.youtube.com/embed/GPCCP-puAzY" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Anchor
tpOperatorsBirtAndAdvect
How to create and advect thinkingParticles using Phoenix FD
Align
aligncenter
HTML
<iframe width="960" height="540" src="https://www.youtube.com/embed/qPOKh_iemB4" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Anchor
TexUvwInheritUVs
TexUvwInheritUVs
How to inherit the UVs of your emitter objects using TexUVW
Align
aligncenter
HTML
<iframe width="960" height="540" src="https://www.youtube.com/embed/IDDDt4XvZpU" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Anchor
TexUvwAddMoreDetail
TexUvwAddMoreDetail
How to add more detail to the color and opacity of volumes using TexUVW
Align
aligncenter
HTML
<iframe width="960" height="540" src="https://www.youtube.com/embed/HMyqcKXAdcc" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Anchor
EmitSmokeByDistance
EmitSmokeByDistance
How to spawn smoke along a surface using the Voxel Tuner
Align
aligncenter
HTML
<iframe width="960" height="540" src="https://www.youtube.com/embed/o2vsk1xqzw8" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Anchor
EmitSmokeByTemperature
How to emit smoke when temperature reaches certain value using the Voxel Tuner
Align
aligncenter
HTML
<iframe width="960" height="540" src="https://www.youtube.com/embed/Fjm8m5Si5Ig" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Anchor
DivideLiquidsByColor
How to mix and divide liquids based on their color with the Particle Tuner
Align
aligncenter
HTML
<iframe width="960" height="540" src="https://www.youtube.com/embed/rq8eyiHiF5A" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Anchor
DeleteBasedOnVelocity
How to delete particles using Velocity data with the Particle Tuner
Align
aligncenter
HTML
<iframe width="960" height="540" src="https://www.youtube.com/embed/5zW3Y7cWYRM" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Anchor
ObjectMelting
ObjectMelting
How to melt an object using the Particle Tuner
Align
aligncenter
HTML
<iframe width="960" height="540" src="https://www.youtube.com/embed/OFGf0m43AB0" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Anchor
RedshiftRendering
RedshiftRendering
How to render Phoenix FD VDB caches with Redshift
Align
aligncenter
HTML
<iframe width="960" height="540" src="https://www.youtube.com/embed/K5MlUcPcvlE" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Anchor
ArnoldRendering
ArnoldRendering
How to render Phoenix FD VDB caches with Arnold
Align
aligncenter
HTML
<iframe width="960" height="540" src="https://www.youtube.com/embed/ZwV30QgCVPM" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Anchor
restore
restore
How to restore а Phoenix FD simulation
Align
aligncenter
HTML
<iframe width="960" height="540" src="https://www.youtube.com/embed/DCzcXzRDd3o" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Anchor
backburnerSim
backburnerSim
Simulation with Phoenix FD using Autodesk Backburner
Align
aligncenter
HTML
<iframe width="960" height="540" src="https://www.youtube.com/embed/sd_82WIka6E" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
UI Expand
titleSimulation with Autodesk Backburner
UI Steps
sizesmall
UI Step
Click the Phoenix Simulator → Output rollout → Set output cache file location.
UI Step
Start Backburner Manager, Server and Monitor.
Default Path: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Autodesk Backburner 20xx
UI Step
In the Backburner Monitor go to Manager → Connect manager and set the corresponding IP address.
UI Step
Click the Phoenix FD top menu → Submit Simulation to Backburner.
UI Step
Set the name or the IP address for the Backburner Manager.
UI Step
Turn on "Run only the Simulation and do Not Render".
UI Step
Press the "Run" button.
Anchor
useWetmap
useWetmap
How to use Phoenix FD Wetmap
UI Expand
titleUsing Phoenix FD Wetmap
UI Steps
sizesmall
UI Step
Click the Phoenix Simulator → Dynamics rollout → Enable "Wetting".
UI Step
Click the Phoenix Simulator → Output rollout → Make sure that the Wetmap particles are enabled for export.
UI Step
Open the Material editor and create two V-Ray materials.
UI Step
Create a V-Ray Blend Material and connect the already created V-Ray materials as Base color and Coat 1.
UI Step
Create a Phoenix Particle Texture → Select the Source Particle System → Select the Phoenix Simulator and pick the Wetmap particle group.
UI Step
Connect the Phoenix Particle Texture as a blend amount mask for the V-Ray Blend Material.
UI Step
Assign the V-Ray Blend Material to your geometry and render.
Anchor
exportAlembic
exportAlembic
How to export a Phoenix FD cache to Alembic
UI Expand
titleExporting the Liquid Mesh
UI Steps
sizesmall
UI Step
Set Phoenix Simulator → Export rollout → Export As: Mesh.
UI Step
Go to File → Export → Export Selected... (with the Phoenix Simulator selected).
UI Step
Under the Alembic Export Options dialog, make sure Extra Channels is set to UVW. Set the Animation → Range according to your needs.
UI Expand
titleExporting Particles
UI Steps
sizesmall
UI Step
Set Phoenix Simulator → Export rollout → Export As: Particles.
UI Step
Select the Phoenix Particle Group in the Scene Explorer and go to File → Export → Export Selected...
UI Step
UI Expand
titleImporting through a V-Ray Proxy
UI Steps
sizesmall
UI Step
Create a Standard Primitives → V-Ray → V-Ray Proxy and select the exported alembic file.
UI Step
When loading a sequence of Alembic files, you can use the "#" symbol as a hint to V-Ray that the file path is a sequence. "C;\alembic_0001.abc' becomes 'C:\alembic_####.abc".
UI Step
You can assign any V-Ray material to the imported alembic files.
In 3ds Max, while you have "Export as" set to "Mesh", the vertex velocity is in Map Channel 2 of the mesh, named "velocity". 3ds Max's built-in exporter names the Color Set in the exported Alembic file "Max_Map_Channel velocity".
Importing the Alembic file back into 3ds Max via the 3ds Max built-in Alembic importer requires you to set the "Velocity channel" to 2 in the V-Ray object properties dialogue, so you can render it with motion blur using V-Ray.
Importing the Alembic file in any host via VRayProxy will render with motion blur without any additional adjustments. It requires V-Ray Next Update 1.1, or newer.
UI Text Box
typenote
Importing the vertex velocity of the Alembic file into Maya using Maya's native importer (Cache → Alembic Cache → Import Alembic) is not supported.
Anchor
SurfTex
SurfTex
How to use Phoenix FD Surface Texture
UI Expand
titleTexture-Based Mesh
UI Steps
sizesmall
UI Step
Set Phoenix Simulator → Rendering rollout → Surface section drop-down to Texture.
UI Step
Click the No Map button and assign a texture (e.g. Cellular).
UI Step
Make sure that Phoenix Simulator → Preview rollout → Show Mesh is enabled. The generated mesh should now be visible in the Viewport.
UI Step
Tweak the Phoenix Simulator → Rendering rollout → Surface section → Isosurface Level parameter if necessary.
Anchor
exportVDB
exportVDB
How to export a Phoenix FD simulation to OpenVDB
