width55%
UI Text Box
typeinfo
Frame range and Frame step parameters are available only for the Animation output type. Those parameters are especially useful if you have failed frames.
Frame range – Specifies a frame range to be rendered. You can specify non-sequential animation frames, e.g. 1-3,7,9,12-15.
Frame step – Specifies a frame step in the frame range for rendering. For example, writing 8 in the Frame step box, will render every eight frame, hence the eight, the sixteenth, the twenty-fourth, etc. Note that the first frame is always rendered.
These filter buttons allow you to select only certain frames.
All – If the parent animation scene has more frames submitted than rendered, it selects all of them to be rendered in the clone job.
Uncompleted – Selects all frames which haven't completed rendering - failed, stopped, paused.
PreviousSelects only the rendered frames from the parent job.
RemainingSelects all submitted, but not rendered frames (e.g. used Frame Step option or a frame range). For example, if you submitted 100 frames, but rendered every 10th frame, the Remaining filter adds 1-9, 11-19, ..., 91-99 frames.
width5%
width40%
width55%
When cloning a V-Ray GPU job this rollout allows you to override the render engine to render with CUDA on CPU only.
CUDA CPU Override – When enabled, the job starts on a machine without GPU hardware and renders with CUDA on CPU only. Note that this may take significantly longer time to complete rendering.
UI Text Box
typenote
CUDA CPU Override option is useful when:
  • there is no GPU hardware available to render the V-Ray GPU job
  • the 16 GB of memory, available on the GPU hardware that Chaos Cloud uses, are not enough for the job to render
Reset to pervious – Resets the render engine to render on GPU only by disabling the CUDA CPU Override option.
UI Text Box
typeinfo
When the cloned job is rendered, you can see whether it is a V-Ray GPU or a V-Ray job in the Job Details. If it is a V-Ray GPU job, Chaos Cloud shows whether it has rendered only on CPU.
Expand
titleClick here to see the image...
width5%
width40%
