Command | Flag(s) | Flag meaning | Function | Examples |
auth login | – | – | Logs in to Chaos Cloud. | ccloud auth login |
auth logout | – | – | Logs out of Chaos Cloud. | ccloud auth logout |
pack | -h, --help, --output (string) --sceneFile (string) | Help for pack Output directory Path to a .vrscene file | Pack a V-Ray scene and all of its assets into a single directory. The result from this operation is a directory, called 'package' which contains everything this scene needs to be rendered with V-Ray Standalone. The name of the package directory is the same as the name of the scene file. All the resources referenced in the .vrscene file are set together into a 'resources' sub directory in the package. The .vrscene file itself is copied as well but transformed so that relative paths to these resources are used instead of the original paths, which may be absolute. This ensures the scene can then be rendered on other computers. | ccloud pack --sceneFile /drive/me/scenes/alfa-red-scene/alfa-red.vrscene --output /drive/me/store/ |
eula | – | – | Prints out the EULA. | ccloud eula |
job cancel | --id (required) | Render Job ID | Cancels a Chaos Cloud job. | ccloud job cancel --id=X8hC6Xg2cb8JeL5 |
job delete | --id (required) | Render Job ID | Deletes a Chaos Cloud job. | ccloud job delete --id=X8hC6Xg2cb8JeL5 |
job download | --id (required) --no-progress --output (required) | Render Job ID Do not display progress when downloading Path to output folder | Downloads outputs of a Chaos Cloud job. Multiple jobs can be requested with multiple instances of the --id flag or by separating them with commas, e.g.: 'job1,job2,job3'. | ccloud job download --id=X8hC6Xg2cb8JeL5 --output="C:\Users\Me\Desktop" ccloud job download --id JobID1,JobID2,JobID3 --output "C:\Users\Me\Desktop" |
job list | --format (string) --name (string) --project (string) --status (string) | –
– – – | Sets the format of each job line. Formatting is done via 'verbs', each of which corresponds to a particular property of the job. Verbs are added in double curly braces, following a dot, e.g. '.Verb'. The supported verbs for a job are: Name, ID, Status, Project, CreatedAt. Special formats such as 'full' are recognized. They define a particular format string. If the --json global flag is used, then --format is ignored and JSON is always emitted for every job. (default ".ID\t{{.Name}}") Filters only jobs which have one of the names. Filters only jobs which belong to this project. Filters jobs with this status. Possible statuses: uploading, upload-failed, upload-cancelled, uploaded, submitted, active, completed, failed, cancelled, paused. | ccloud job list --project PROJ1 --project PROJ2 |
job pause | --id (required) | Render Job ID | Pauses a Chaos Cloud job. | ccloud job pause --id=X8hC6Xg2cb8JeL5 |
job rename | --id (required) --title (required) | Render Job ID The new title of the V-Ray Cloud job | Renames a Chaos Cloud job. | ccloud job rename --id=X8hC6Xg2cb8JeL5 --title="Marbles" |
job submit | --sceneFile (required) --animation --colorCorrectionsFile --creditLimit --frameRange --frameStep --height --width --ignoreWarnings --name --no-progress --preserveAlpha --project --allCameras --batchFile* --onlyUpload --downloadOutput --camera (stringArray) | Path to .vrscene file Renders animation instead of a single shot Path to color corrections file Sets credit limit per job (still images only) Frame range of the animation Frame step of the animation Height of the rendered image Width of the rendered image Ignore warnings in scene file processing Name of the rendering job Do not display progress while submitting Preserve alpha channel of PNG output Name of the rendering project Render all cameras in the scene. Applicable for multi-camera scenes String Path to a JSON file which describes a batch submit Uploads the scene without rendering Uploads a set of scenes, waits them to complete rendering and download the outputs Render specific cameras. The names given need to match those of the cameras in your scene, which you want to render. | Submits a V-Ray scene to Chaos Cloud. | ccloud job submit --sceneFile="C:\Users\Me\Desktop\soccer.vrscene--project="Project Cloud" --width=1280 --height=720 --creditLimit 0.01 ccloud job submit --batchFile { |
job resubmit | --id (required) --animation --colorCorrectionsFile --frameRange --frameStep --height --width --ignoreWarnings --name --no-progress --preserveAlpha --project --onlyUncompleted | Render Job ID Renders animation instead of a single shot Path to color corrections file Frame range of the animation Frame step of the animation Height of the rendered image Width of the rendered image Ignore warnings in scene file processing Name of the rendering job Do not display progress while submitting Preserve alpha channel of PNG output Name of the rendering project Clones a job only with the frames that are not in a completed state (failed, canceled, paused) | Resubmits a V-Ray scene to Chaos Cloud. | ccloud job resubmit --sceneFile="C:\Users\Me\Desktop\soccer.vrscene --project="Chaosology" --animation --frameRange=30 --ignoreWarnings |
job start | --id (required) | Render Job ID | Starts a V-Ray Cloud job. | ccloud job start --id=X40YITIaqtb_94E |
job status | --id (required) | Render Job ID | Prints status info for a Chaos Cloud job. If an animation has uncompleted frames, it prints information about them, too. | |
job report | --json (required) --id (required) | Formats the data into a .json message. The ID of the job, for which the report is generated. There can be multiple ID flags, depending on how many jobs need to be included in the report. | Fetches report information on specified jobs and formats it into a .json file. | --json job report --id X8hC6Xg2cb8JeL5 --id X40YITIaqtb_94E |
project create | --name (required) --default | Name of the project Marks the project as default | Creates a new project. | ccloud project create --name="Cloudy" --default |
project delete | --name (required) | Name of the project | Deletes a project. | ccloud project delete --name="Drains" |
project list | – | – | Lists available projects. | ccloud project list |
project rename | --name (required) --to (required) | Name of the project The new name of the project | Renames a Chaos Cloud project. | ccloud project rename --name="Marbles" --to="Drains" |
update | – | – | Updates the Chaos Cloud client. | ccloud update |
version | – | – | Prints Chaos Cloud client version info. | ccloud version |
version check | – | – | Prints out if there is a newer version than the installed and/or if the current version is deprecated. | ccloud version check |
help | – | – | Prints command information. | ccloud help; ccloud job help; ccloud job submit help |
