Distributed rendering is the process in which several machines in a network are used to render a single image. The machine which distributes the tasks is called a Render Master Client and all other machines are called Render SlavesServers.
Render
Servers Setup
To set up a Render Slave you Server you need to run V-Ray Standalone. In the console type
where n is the network port number that is going to be used for Distributed Rendering. Please make sure it matches the one set in the Render Master setupClient setup.
Render
Client Setup
In the Render settings, open the System panel and click Enable Distributed rendering . This will enable a new panel called Distributed Rendering which holds all the options seen below.
Set the port number. Make sure it matches the port number set for the render slavesservers.
Add render slaves by servers by pressing the +/- button on the right. Specify an IP address or host name. You can use the check box on the right of each Render slave to server to quickly include or exclude it from the distributed rendering.
