This page provides some information on how to get V-Ray up and running.
UI Button | ||||||||||
Installing V-Ray
The V-Ray installer for Modo is straightforward and easy to follow. It can be downloaded from the V-Ray | Downloads section of the Chaos Group website (make sure you use your login credentials to ensure access to the download links). Before installing V-Ray, it is recommended to check that your computer meets the System Requirements for running Modo with V-Ray. If you would like a step-by-step guide, check out the Installation of V-Ray for Modo page. If you run into any problems during installation, check out the Troubleshooting page.
