This page provides information about V-Ray supported version of platforms that can make use of Chaos Cloud.
UI Text Box
size
typenote
Each Chaos Cloud job is rendered with the latest publicly available build of the V-Ray version used to create the original scene, e.g. a scene created with V-Ray Next is rendered with the latest publicly available version of V-Ray Next.
medium
UI Text Box
typenote
Please note, that each Important about scenes created with V-Ray 3: All failed jobs created with V-Ray version 3 .6 and above can export a .vrscene file that can be rendered in Chaos Cloudwill still be automatically refunded. However, issues with such jobs won't be investigated by the Chaos Support teams as V-Ray 3 is officially not supported anymore.
V-Ray 5
WindowsLinuxmacOS
3ds Max® 2016 and later--
Maya 2017 and laterMaya 2017 and laterMaya 2017 and later
SketchUp 2017 and later-SketchUp 2017 and later
Rhinoceros Rhino v6.29.20238 or and later
Rhino v7.0.20314 or and later
Cinema 4D R20 or and later-Cinema 4D R20 or and later
Autodesk Revit 2018 and later-
V-Ray Next
WindowsLinuxmacOS
3ds Max® 2013 and later- 2021--
Maya 2015 and later- 2021Maya 2015 and later- 2021Maya 2016.5 and later- 2021
Houdini 1618.5.473 499 and abovelaterHoudini 18.5.499 and laterHoudini 18.5.499 and later 16.0, Houdini 16.5 and Houdini 17.0Houdini 16.0, Houdini 16.5 and Houdini 17.0
Rhino 5.14 or and later (64-bit versions only);
Rhino 6.13.19058 or  and later
SketchUp 2016 (64-bit) and later- 2020-SketchUp 2016 (64-bit) and later- 2020
Autodesk Revit 2015 and later- 2019--
Modo 901 and later-Modo 901 and later- Modo 13
V-Ray 3.6
WindowsmacOS
Cinema 4D R18 and later *Cinema 4D R18 and later *
Modo 701 (SP5), 801 (SP2 or higher) and laterModo 701 (SP5), 801 (SP2 or higher) and later
Rhino 6.6.18117 or and later
SketchUp 2015 and laterSketchUp 2015 and later
