UI Text Box | ||
Each Chaos Cloud job is rendered with the latest publicly available build of the V-Ray version used to create the original scene, e.g. a scene created with V-Ray Next is rendered with the latest publicly available version of V-Ray Next. |
UI Text Box | ||
Chaos Support team provides support for the following products: - V-Ray 6 for: 3ds Max, Maya, SketchUp, Rhino, and Cinema 4D - V-Ray 5 for: 3ds Max, Maya, Houdini, SketchUp, Rhino, Revit, and Cinema 4D - V-Ray Next for: Revit, Houdini, and Modo Important about scenes created with V-Ray 3: All failed jobs created with earlier V-Ray 3 versions will still be automatically refunded. However, issues with such jobs won't be investigated by the Chaos Support teams as . |
Cloud Rendering Compatibility
Product Versions | V-Ray 6 | V-Ray |
5 | V-Ray Next |
V-Ray |
3.6 | |||||||||||
Windows | Linux | macOS | Windows | Linux | macOS | Windows | Linux | macOS | Windows | Linux | macOS |
3ds |
Max® | 2018 or later | - | - | 2016 & later | - | - | 2013 - 2021 | - | - | - | - | - |
Maya | 2019 & later | 2019 & later | 2019 & later | 2017 & later | 2017 & later | 2017 & later | 2015 - 2021 | 2015 - 2021 | 2016.5 - 2021 | - |
Rhino v6.29.20238 and later
Rhino v7.0.20314 and later- | - | |
Cinema 4D | R20 |
&later | - |
R20 & later | R20 & later | - | R20 & |
later | - |
- | R18 & later* | - | R18 & later* |
Houdini | - |
Windows | Linux | macOS | ||||||||||||||||
Maya 2015 - 2021 | Maya 2015 - 2021 | Maya 2016.5 - 2021 | ||||||||||||||||
18.5, 19.0, 19.5 | 18.5, 19.0, 19.5 | 18.5, 19.0, 19.5 | Houdini18.5.499 | and& later | Houdini18.5.499 | and& later | Houdini18.5.499 | and later& later | - | - | - | |||||||
Revit | - | - | - | 2018 & later | - | - | 2015 - 2019 | - | - | 2015 & later | - | - | ||||||
Rhino | v6.29.20238 & later v7.0.20314 & later | - | - | v6.29.20238 & later v7.0.20314 & later | - | - | 5.14 & | Rhino 5.14 and later (64-bit | versions only) | ;Rhino 6 | 6.13 | .19058.19058 & later | - | - | 5.14 & later (64-bit only) 6.6.18117 & | and later | - | - |
SketchUp | 2019 - 2022 | - | 2019 - 2022 | 2017 & later | - | 2017 & later | 2016 (64-bit) - 2020 | - | SketchUp2016 (64-bit) - 2020 | Revit2015 | - 2019and later | - | -2015 & later | |||||
Modo | 901 and later- | Modo 901- | Modo 13
Windows | - | macOS | Cinema 4D R18 and later * | Cinema 4D R18 and later *- | 901 & later | - | 901-13 | Modo 701 (SP5) | , 801 (SP2 or higher) | and & later | - | Modo 701 (SP5) | , 801 (SP2 or higher) | and later
Rhino 5.14 and later (64-bit versions only); Rhino 6.6.18117 and later | - | ||||||||||||
SketchUp 2015 and later | SketchUp 2015 and later | ||||||||||||
Revit 2015 and later | - | ||||||||||||
& later |
UI Text Box |
*Only still images are supported in Chaos Cloud rendering with V-Ray 3.7 for Cinema 4D. |
Chaos Support
Product | V-Ray 6 | V-Ray 5 | V-Ray Next |
3ds Max® | |||
Maya | |||
Cinema 4D | |||
Houdini | |||
Revit | |||
Rhino | |||
SketchUp | |||
Modo |
