This page describes how to set up your local system so that it loads the files for the correct version. The notes here are for the Windows, Linux, and macOS operating systems.
UI Text Box
typewarning
Starting with V-Ray 6, the Portable Installation replaces the zip builds. Please visit the Portable Installation page to find out more
UI Button
colorblue
newWindowtrue
icondownload
titleDownload V-Ray for Standalone
urlhttps://download.chaosgroup.com/?platform=47&product=47
Tabs Container
directionhorizontal
Tabs Page
titleWindows
  1. Download V-Ray Standalone from the Chaos website. The file should be called vraystd_adv_5xxxx6xxxx_x64_vc14.zip.
  2. Make a new directory anywhere on your machine or on a network location and call it vray_builds (vray_builds is an arbitrary name, you can use whatever name suits you). For example, create a vray_builds directory on your D:\ drive.
  3. Make another directory inside vray_builds and name it vray5xxxxvray6xxxx_std.
  4. Unpack vraystd_adv_5xxxx6xxxx_x64_vc14.zip into the vray5xxxxvray6xxxx_std directory.
UI Text Box
typeinfo
The D:\ drive holding the vray_builds folder is simply an example. The unpacked V-Ray ZIP installation can be placed anywhere.
UI Text Box
typenote
The vray.exe file is located in the bin folder.
Tabs Page
titleLinux
    5xxxx
    6xxxx_
    linux_x64_vc14
    centos7_clang-gcc-6.3.zip.
  2. Make a new directory anywhere on your machine or on a network location and call it vray_builds (vray_builds is an arbitrary name, you can use whatever name suits you). For example, create a vray_builds directory on your /opt/ directory.
  4. Unpack vraystd_adv_5xxxx6xxxx_linux_x64_vc14centos7_clang-gcc-6.3.zip into the vray5xxxxvray6xxxx_std directory.
UI Text Box
typeinfo
The /opt directory on Linux is simply an example. The unpacked V-Ray ZIP installation can be placed anywhere.
UI Text Box
typenote
The vray.bin file is located in the bin folder.
Tabs Page
titlemacOS
    5xxxx
    6xxx_mavericks_x64_
    vc14
    gcc-4.2-cpp.zip.
  2. Make a new directory anywhere on your machine or on a network location and call it vray_builds (vray_builds is an arbitrary name, you can use whatever name suits you). For example, navigate to your /Applications directory using cd / and create a vray_builds directory in your /Volumes/Data directory.
  4. Unpack vraystd_adv_5xxxx6xxxx_mavericks_x64_vc14gcc-4.2-cpp.zip into the vray5xxxxvray6xxxx_std directory.
UI Text Box
typeinfo
The /Volumes/ Applications Data directory is simply an example. The unpacked V-Ray ZIP installation can be placed anywhere.
UI Text Box
typenote
Tabs Container
titleEnvironment variables
directionhorizontal
Tabs Page
titleWindows
UI Text Box
typeinfo
The example directory and version names below are for V-Ray Standalone on Windows where  where vraystd_adv_4xxxx6xxxx_x64_vc14.zip has been unpacked into D:\vray_builds\vray5xxxxvray6xxxx_std\.
Here is a list of the environment variables and their description and examples. An example of a complete setup will be given further below.
OSActionVariableLocationDescriptionExample
WindowsSetVRAY_OSL_PATH\openslRequired for the OSL definitions of the OSL plugin.set VRAY_OSL_PATH=D:\vray_builds\vray5xxxxvray6xxxx_std\opensl
WindowsSet
VRAY_AUTH_CLIENT_FILE_PATH 1
arbitrary locationPoints V-Ray to a V-Ray license.set VRAY_AUTH_CLIENT_FILE_PATH=<folder_containing_vrlclient.xml>
UI Text Box
typeinfo
Since V-Ray 6, update 1, the VRAY_OSL_PATH variable has been deprecated and no longer needs to be set.
Tabs Page
titleLinux
UI Text Box
typeinfo
The example directory and version names below are for V-Ray for Maya 20202022 on Linux where vray_adv_5000160000_maya2020maya2022_linux_x64.zip has been unpacked into /opt/vray_builds/vray50001vray60000_maya2020maya2022/.
LinuxSetVRAY_OSL_PATH/openslRequired for the OSL definitions of the OSL plugin.export VRAY_OSL_PATH=/opt/vray_builds/vray5xxxxvray6xxxx_std/opensl
LinuxExtend
LD_LIBRARY_PATH 3
/lib
(for earlier builds: vray /lib/linux_x64/clang-gcc-4.8(recent builds: vray/lib)
Required to run V-Ray itself.
export LD_LIBRARY_PATH=/opt/vray_builds/vray5xxxxvray6xxxx_std/vray/lib/linux_x64/clang-gcc-4.8:$LD_LIBRARY_PATH
for V-Ray Next Standalone Update , update 2 and laterearlier:
LinuxSetVRAY_AUTH_CLIENT_FILE_PATH 1arbitrary locationPoints V-Ray to a V-Ray license.export VRAY_AUTH_CLIENT_FILE_PATH=<folder_containing_vrlclient.xml>
UI Text Box
typeinfo
Tabs Page
titlemacOS
Tabs Page
titleLinux
UI Text Box
typeinfo
The example directory and version names below are for V-Ray for Maya 20202022 on macOS where vray_adv_5000160000_maya2020maya2022_mavericks_x64.zip has been unpacked into /vray_builds/vray50001vray60000_maya2020maya2022/.
macOSSetVRAY_OSL_PATH/openslRequired for the OSL definitions of the OSL plugin.export VRAY_OSL_PATH=/vray_builds/
vray4xxxx
macOSExtend
DYLD_LIBRARY_PATH 2
/lib
(for earlier builds: /vray/lib/mavericks_x64/gcc-4.2-cpp
(recent builds: /vray/lib
export DYLD_LIBRARY_PATH=/vray_builds/
vray5xxxx
vray6xxxx_std
/vray
/lib
:$DYLD_LIBRARY_PATH
for builds
after
before 2019-03-12:
vray5xxxx
vray6xxxx_std/vray/lib/mavericks_x64/gcc-4.2-cpp:$DYLD_LIBRARY_PATH
macOSSetVRAY_AUTH_CLIENT_FILE_PATH 1arbitrary locationPoints V-Ray to a V-Ray license.export VRAY_AUTH_CLIENT_FILE_PATH=<folder_containing_vrlclient.xml>
UI Text Box
typeinfo
