Run the installation file from the command prompt with the -gui=0 argument.
vray_adv_50ххх60ххх_max20nn_x64.exe -gui=0
Follow the instructions and set up the installation the way you want to have it on all machines. This creates a file named config.xml in the folder of the installation file.
In the second step, run the installer with the following command:
Code Block |
vray_adv_5000560004_max2021max2023_x64.exe -gui=0 -configFile="xml_file.xml" -quiet=1 -auto |
Code Block | ||||
<STDROOT>\uninstall>installer.exe -uninstall="<STDROOT>\uninstall\install.log" -uninstallApp="V-Ray 56 for 3ds Max ####" -auto -quiet=0 |
