Multiexcerpt | |||||||||||||||||||||||||||||||||||||||
This page provides information on installing V-Ray for 3ds Max. OverviewThis guide is to serve as a reference for installing V-Ray for 3ds Max and 3ds Max Design. A complete installation of V-Ray for 3ds Max consists of V-Ray, V-Ray GPU, V-Ray Standalone, V-Ray DR Spawner, V-Ray license server, V-Ray tools, V-Ray SDK, V-Ray Chaos Cloud Client. If you are a trial user, please refer to the Trial installation of V-Ray for 3ds Max, as the process differs from the one showed on this page.
Installing V-Ray for 3ds MaxThe V-Ray installer automatically removes any previous installations. This allows you to seamlessly upgrade from previous versions. If you experience problems, you can manually uninstall the previous versions to perform a clean install. For more information, please refer to the Uninstall V-Ray page.
Before running the installation, make sure your Windows account has administrative privileges. Run the installer. 1. Upon the start of the installation, Windows may ask you for permission to run the installer with administrator privileges. Please confirm.
2. You will be presented with the V-Ray licensing agreement. Please take a moment to review the agreement. Check the I accept the Agreement checkbox and click Install to proceed with standard installation. If you need to customize your V-Ray installation, press the Advanced button.
Advanced Installation Options
Chaos License Server OptionsAt this step you can choose the license server directory. Migrate data during installation – When enabled, transfers all of your settings made with older versions of the License Server, such as enabled dongle subsystem, proxy settings, etc. Disabling this option installs License Server with all settings at their defaults and any custom settings from the previous installation are lost. Add firewall exception – Enabling this option allows the default licensing port (TCP 30304) to pass the firewall. If you disable it at this step, you will need to manually add firewall exceptions later.
4. After you click the Install button, the installer proceeds to uninstall any previous versions and installs V-Ray on your machine. If the installer detects any applications that need to be closed, they are listed before being able to continue. Please close them and click Continue.
5. Once V-Ray installation has finished, the Material Library installation starts. Note that the download process might take awhile. If you abort the download, it affects only the Material Library download and not the whole V-Ray installation. For more information on the Material Library installation process, see the V-Ray Material Library Browser page.
6. Now V-Ray 5 is ready to render!
Check your LicenseOnce the installation of the License Server is done, you are directed to the License Server local host (127.0.0.1:30304) in order to sign in.
For full information on the License Server options and settings, see the Licensing section of the documentation. |
