UI Text Box | ||
V-Ray 6, update 2.1, for 3ds Max supports 3ds Max 2020-2025. V-Ray 6, update 1.1, for 3ds Max supports 3ds Max 2019–2024. V-Ray 6 for 3ds Max still supports 3ds Max 2018; however, several V-Ray features such as V-Ray Proxy hierarchy, batch loading multi-sub textures, and faster UI , require 3ds Max 2019 or newer to work. Cloud collaboration in the VFB requires 3ds Max 2020 or newer to work. |
Processor | Intel 641, AMD64 or compatible processor with SSE4.2 support |
RAM | Minimum 8 GB RAM, recommended 64 GB RAM |
Operating system | Microsoft® Windows 10 or Windows 11 operating system |
Autodesk® 3ds Max | 3ds Max® 2019*, 2020, 2021, 2022, 2023, 2024, and 2024 2025 (64-bit) |
USB port | Required for customers using legacy hardware lock, preferably USB 2.0 |
TCP/IP | Only IPv4 required for distributed rendering is supported. IPv6 is currently not supported. |
License Server | 6.0.0 or later |
GPU Acceleration | NVIDIA CUDA with minimum required compute capability 5.22: Maxwell-, Pascal-, Volta-, Turing-, and Ampere-based NVIDIA card(s); NVIDIA RTX with compute capability 5.22: RTX cards with latest recommended video driver3; 2GB VRAM V-Ray Production Denoiser: AMD or NVIDIA GPU supporting OpenCL 1.2; NVIDIA AI Denoiser: Maxwell-, Pascal-, Volta-, Turing-, and Ampere-based NVIDIA card with latest recommended video driver3 |
1 – Windows 11 is required for running Intel Alder Lake processors.
2 – CUDA compute capability and card reference
3 – With V-Ray 6, using older drivers (less than 495.xx) on Ampere cards may lead to incorrect render results with RTX. More information on V-Ray GPU is available at Chaos.com.
* See the blue note at the top of the page.
