Example: Translucency Value (Front vs. Back Material)
In
this example, the leaves have both front and back materials connected to the 2Sided Material. Notice how the leaves change when the Translucency value (shown in RGB) is changed. The last render uses a Translucency grayscale map.
Section | |||||||||||||||||||||||||||||||||||||||||||
In this example, the lampshade uses a 2Sided material with only a Front material connected (VRayMtl). A V-Ray sphere light is used to illuminate the inside. Translucency is shown here with grayscale values (RGB).
Example: Usage examples
These are some examples of common usage for the V-Ray 2-sided Material
Example: Common Usage
Fancy Bullets | ||
