Section | |||||||||||||||||||||||||
Anchor | ||||
Example: Tiling Factor
This example shows the effect of the Tiling Factor parameter. The .vrscan material used for the example is Leather.
Section | |||||||||||||||||||||||||||||||||||||||||||||
Anchor | ||||
Example: Saturation
This example shows the effect of the Saturation parameter. The .vrscan material used for the example is Leather.
Anchor | ||||
Example: Filter Color
This example demonstrates the effect of the Filter Color parameter. In the second image, Filter Color is set to 0.5 and rgb (45, 10, 0).
Fancy Bullets | ||
V-Ray GPU render engine supports VRayScannedMtl under few limitations. In general, if your renderer is set to V-Ray GPU the unsupported features will be grayed out.
